Bought brand new m&h race masters for my car (325/45r17) and they're a little over a month old maybe 40 days on the car exactly and they're completely f***ed. I have one burnout on these tires and it was no John force burnout simply enough to heat/clean the tire up before a pull. They maybe have 1500 miles on the set and that's guessing high. What are you guys getting out of these my mickeys lasted way longer.... Wish they made the same size.
That sucks. Must of been the same issue I was having w/ the exhaust falling on my head. Bet you it got stuck under your tire & ripped them up. Sorry to hear that bud
Crazy you have this problem, aren't you pushing your car ?
Was also thinking alignment and / or pressure. One of mine wore on the inside (not as bad) and I realized that dropping the rear cradle put the alignment way off.
Check your alignment. You can see you have some negative camber, but that won't really wear out the tires that fast. If the toe is off it can quickly accelerate tire life.
like others have said, I've seen similar wear patterns on other cars I've owned and that looks like rear alignment issue. getting a good straight line focused alignment will help traction a small amount too so it's good to have done anyway.
