Rear mounted external trans cooler
Anyone mount an external cooler w/fan around the rear cradle of a C6? If so which one did you use, where/how did you mount it, and how cool is your fluid temp?
Thanks in advance for your feedback.
I've been wondering if anyone had thought of doing this. I was looking at the possibly of putting it somewhere in the space behind the left rear wheel. I think it's doable and I had pretty much figured out how the lines could be routed to it too. You would pretty much have to reroute the lines from where they leave the transmission case.
You would obviously need one of the trans fluid cooling modules with the fan attached and you would want the most efficient cooler that you can get. The bigger B&M unit would probably be the shot.
Received 1,194 Likes
St. Jude Donor '15
Sounds like a neat idea to me
When I got an auto swap on my C5Z, they put a B&M 70297 on the back. It's bolted to the cradle and just fits between the exhaust pipes. It worked ok, but the trans temps were always over 200 degrees even with the fan. I wanted more cooling, so I eventually added a front mount in series as well.
Looks just like what I want to do with my car.
Which hood is that? Siebon? Did you wrap the roof?
The twin cooler up front should work real nice.
What temps do you normally see and what kind of mods, stall converter, do you have?
Thanks man! the roof is glass and I had the Halo painted gloss black. Hood is a carbon creations hood. not the best looking hood but not bad for the money. I just had a FTI 3600 triple disc installed so wanted to make sure tranny temps stayed cool. In 90degree weather i see trans temps around 180 after making 2-3 pulls. Still running through factory radiator to transcoolers to get trans to operating temp quickly since the car is driven on the street ALOT. (so essentially have 3 coolers...2 in fog lights, one in radiator.) If i wanted to get it really cool i could bypass the rad but as of right now it isn't necessary. And if i want to have the trans freeze over I guess i could always add some SPAL fans to the coolers too haha
I would say to the OP that whilst it might make for a neat project to mount a fancy cooler/fan module at the rear of the car, it really doesn't make sense to blaze the trail on this, and the reason I haven't messed with it myself is because I don't need to, since my $60.00 bolt-on cooler is doing the job. There's plenty of other stuff for me to spend time and money on. One of them is going to be a carbon hood and wrap the halo and roof, because I really like that look on your car.
Another thing that I'm going to install soon is a B&M high capacity trans pan, that holds another 1.85 quarts of fluid, which I've bought already.
Gent's, thanks for all the responses and pics.
I'm installing a Circle D triple clutch 32-3400 stall to my built 6L80 and wanting to run a cooler for "longevity" (if that word can used in the same sentence as automatic). I'm really wanting to stay away from mounting one up front just because I don't want to run the factory lines up through the headers (or any lines up front for that matter). I also am wanting to stay away from the radiator. The car is basically a street/strip car and not a daily.
I know the C7's are running them in the rear left qtr but they have the vent on top for air. Was hoping someone was keeping temps below 200* with a rear mounted cooler/fan.
I actually thought about running one in place of the fog lights but really don't want to go upfront.
I did find a post Canuk replied too about this cooler, but again the post was a front mount and still utilized the radiator. Still has some good info. Here's the link for reference if you want to read.
https://www.corvetteforum.com/forums...right-way.html
Will keep you posted on what I decide. Again, thanks for all the input.
So true. People ask for opinions. Get accurate answers from people who have actually done it and proven it.......then end up doing the total opposite, spending more times/money, and end up experiencing less than desirable results.
The only opinion you have is what your shop sold you. Don't come in my thread ball busting with your with your gibberish when you have nothing but receipts.
Dude_man (06-27-2016)
lol actually i have had that opinion long before i even took my car to that shop. have seen that same setup work time and time again on other cars. but go ahead and make your "custom" setup in the most inefficient location and go against what makes the most sense. To me thats gibberish. Good luck keeping that tranny cool
I've put the cooler in the rear of my old c6z and now my turbo charged zr1..
I didn't feel like it was a good choice cramping more crap up in the front of the car, and have to add twice the lines and fittings..
Plus I figured the less weight on the front and the more weight on the back the better off I was when trying to get the car to plant the tires...
