C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Head gasket
Old Oct 17, 2016 | 11:17 AM
curtisb23's Avatar
curtisb23
Originally Posted by c5mtl
I say to much timing ...my heads looked like that but all my cylinders were leaking . You need to be careful cause if your blowing coolant out of the overflow it can get on your tires or on track surface and then your in big trouble or the guy after you is in trouble. 24-27 psi Is super aggressive you want to forget all this ls9 gasket stuff....call Texas speed and ask about their fire ring gaskets.....expensive but the seal even under the most insane setups ....guys on yellow bullet are putting 45psi through them on 4 bolt heads ....do it once and be done with it!!!
http://www.texas-speed.com/p-5047-pf...re-single.aspx
I'm not on that much timing . It's on 20 degrees on ethanol. Oem gaskets where not up to the boost life
