C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS stage 1 fuel system
Old Nov 20, 2016 | 09:24 PM
russ472's Avatar
russ472
Default ECS stage 1 fuel system
I installed my stage 1 fuel system today. I jumped the relay to make sure the system worked and to check for leaks before reinstalled rear inner wheel well.
I can't log fuel pressure (no sender). What is the easiest way to insure it is turning on while under boost without buying a pressure sending unit?
Old Nov 20, 2016 | 09:55 PM
90zcrex's Avatar
90zcrex
You can run a simple led off the voltage at the pump which would tell you that you are getting voltage to the pump, but without a fuel pressure switch or sensor the only thing would be your afr going lean. I have the aem fail-safe wideband which checks afr at certain boost levels and will flash red if afr goes lean under boost.
Old Nov 20, 2016 | 10:22 PM
russ472's Avatar
russ472
my fuel system hasn't run lean during boost, but my injector duty cycle is high. hoping this will solve that issue and give me more safety margin.
Old Nov 21, 2016 | 09:43 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The post above yours would be the easiest way to ensure voltage, but the difference in IDC should also be a noticeable difference too.
Thanks for your business!
Old Nov 21, 2016 | 09:59 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, you should notice it go richer if fuel pressure was dropping before (likely it is, to at least some extent)
I had to take quite a bit of fuel out of mine after I added a fuel system
Old Nov 21, 2016 | 07:14 PM
NJ_phil's Avatar
NJ_phil
Buy the pressure sending unit
Old Nov 21, 2016 | 08:01 PM
russ472's Avatar
russ472
I know.....one of many things I have put on the back burner. I have spent a ton of money on this car over the last two years. Clutch and sticky tires are still on the list too. With the sale Doug is having on clutches, I may have to give in.
Old Nov 22, 2016 | 12:19 PM
neverstop's Avatar
neverstop
I was having a problem with my external fuel system not coming on properly from low quality shop that did the previous work, redid the whole thing and when it came on it added over 1 point to my AFR from mid 11s to low 10s at ~900whp. Every car is different and I have no idea who hard you are pushing your setup but if you were running out of fuel before the difference should be noticeable I think.
Old Nov 22, 2016 | 01:25 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It was noticeable for me as well once I wasn't dropping fuel pressure
To ECS stage 1 fuel system
