C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Will my combo kill the blower first or something else?
Old Dec 28, 2016 | 07:22 PM
Dimewise's Avatar
Dimewise
Default Will my combo kill the blower first or something else?
ECS 1500SL with meth, stg 1 fuel, 10% OD balancer and 3.25" pulley.
Will this kill the blower?
Old Dec 28, 2016 | 07:25 PM
Unreal's Avatar
Unreal
Murder it dead for sure. It will probably die from a drug overdose.
Old Dec 28, 2016 | 07:26 PM
Dimewise's Avatar
Dimewise
That response was expected, believe it or not lol.
Old Dec 28, 2016 | 07:35 PM
Dimewise's Avatar
Dimewise
I was trying to hold off on another askhole thread but couldnt find a clear answer... Then I found some posts by MBB. He is or was running the 3.25" with a 10% OD on a 1500. I think ill be ok for now.
Old Dec 28, 2016 | 08:08 PM
Unreal's Avatar
Unreal
Depends on how high you rev it, and how you treat it and beat on it. If you never go above 6k then no big deal. Crank it out to 7500 time and time again and it will need frequent rebuilds.
Old Dec 28, 2016 | 08:24 PM
FeArZ's Avatar
FeArZ
After asking Doug at ECS about this same combo he said shifting at 7000 would be over spinning the blower about 10,000 RPM he advised against this. He also said unless your going for 900hp this is not needed. lol
He advised to pulley up and stay within safe RPM and still should make great power.
Old Dec 28, 2016 | 08:50 PM
Dimewise's Avatar
Dimewise
Sounds like my options are to go with a larger pulley or head unit...
Old Dec 28, 2016 | 09:02 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Or don't spin the **** out of it to 7K+
I'd just do 3.5" to begin with and see if that's enough
Old Dec 29, 2016 | 09:13 AM
Unreal's Avatar
Unreal
Pullies are cheap and take 10 minutes or less to swap. If its a concern and you really want to rev past 6500+rpm, then step up a size and see if you are happy.
Old Dec 30, 2016 | 07:22 AM
GeneSch's Avatar
GeneSch
This is a great question.. Only time will tell, and what works for your set up may be different then others.
I picked up 3 used pulleys. 3.6, 3.4 and 3.25. Put them all on and figured out belt sizes at home.
I have a 10 over Crank. I figured lets start off with the 3.25 and work our way back while on the Dyno. Like Unreal said, 20 min change with the car hot.
3.25 pulley, car was dropping boost off hard around 5,500 5,700 rpm and making more heat. Had to pull timing. Could have been belt slip but the heat would make me think it was over spinning as well.
3.4 pulley picked up one 1# at low RPM and held it till 7,000 RPM and had much less heat. Was able to add some timing. Let it here and ran it all year with no issues.
You should try the same thing. Nothing sucks more then taking your car home to make adjustments and then taking it back weeks later because they are to busy.
Old Dec 30, 2016 | 10:02 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Which blower you running? Meth?
Old Dec 30, 2016 | 10:54 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Plenty of good advice in here!
Old Dec 30, 2016 | 11:28 AM
GeneSch's Avatar
GeneSch
ECS-1500 and alky control. All from Doug.
To Will my combo kill the blower first or something else?
