C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
autolite plugs
Old Mar 3, 2017 | 04:42 PM
johnlaura's Avatar
johnlaura
Cruising
Default autolite plugs
Are Autolite double platinum APP5245, good plugs to use with a 100 shot of nitrous ? if not, what do you guys use. Thanks
Old Mar 5, 2017 | 08:05 PM
inspector12's Avatar
inspector12
Not familiar with that particular plug, I used to run the Autolite 103's with no issues. One heat range colder should be fine for a 100shot. A 6 or a 7 is fine so if it is either of those you should be fine.
Old Mar 5, 2017 | 09:59 PM
russ472's Avatar
russ472
I wouldn't run platinum plugs running nitrous.
To autolite plugs
