What power level do the factory fuel lines become a limiting factor and need to be upgraded?
Or what kind of power are some of yall making on stock fuel lines?
Could be 800 or 1000+ just depends on a lot of stuff. Typically when people upgrade fuel system adding a line is cheap/easy compared to the pumps/etc so you don't see people hitting the limits of the factory feed.
Factory feed line will support more than a single walbro 450 can ever put out. Hell the line is as big or bigger than the fuel pump outlet. So I can't see any need to even consider it with only a single walbro.
The outlet may be smaller but the feed line is much longer which create more friction/pressure drop.
