Direct drive squeal and slipping.
Looks like ECS doesnt make their cog drive anymore and I'm tired of not being able to run the AC whenever I need it. Is anyone running the A&A secondary drive that adds the 4th belt to only turn the jackshaft pulley? Is it a permanent fix?
I have the older design but using the c5 tensioner and green 4 rib belt to drive the AC. Been on for 2 years, tons of dyno pulls and daily driven rain, sun, snow and no issues with the setup.
What can you tell me about this heavy duty tensioner? My tensioner and belt(gatorback) are about a year old. Id much rather change a tensioner with the chance it will help over pulling the balancer to get more ribs cut.
I cant find the info for the tensioner. I will look more this aft. It was just a GM part from rockauto. The have a few models but I forget which one exactly. It had considerably more tension that then one it replaced. A/C used to squeal every time I turned it on, but hasn't since the change.
Mine and everyone I know with a traditional flip drive squeals once the belt brakes in and loosens up. My ECS cog one has been flawless, and I would expect the new A&A one with the 3 belt setup to be the same.
The c5 and new tensioner, and better belt probably helps a lot, and some people like Canuk get away with it, but it seems some people do not.
Just want to revive this thread about the heavy duty AC tensioner
you used? Was it a c5 or c6 AC belt tensioner as I want one with
some more tension. Thanks, Brian
I have the newest A@A flip drive and mine squeals sometimes on cold starts and also after it sits for a little while after driving. Only had it installed like 6months ago. Not sure what belt it is or what exactly to do to determine which one.
Either way that and a gatorback (continental elite) belt got rid of the squealing I was getting whenever I started my AC. Still seems to be fine and we are like 3or 4 years later I think.
rajahhindi (04-25-2018)
That's what mine is doing and 9 months later after install it's getting worse.
