C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Belt size
Old Jun 28, 2017 | 08:06 PM
sm0kinvette's Avatar
sm0kinvette
Default Belt size
Can I use the same belt size for both 3.8" and 4" vortech pulleys
Old Jun 29, 2017 | 12:13 PM
Unreal's Avatar
Unreal
Not enough info to say. Depends on kit, tensioner, belt on there now, etc. Maybe, maybe not.
Old Jun 29, 2017 | 04:20 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There's one easy way to find out
Old Jul 7, 2017 | 05:14 PM
Wilkinshc's Avatar
Wilkinshc
Check your tensioner to see if it is almost maxed out, halfway, or barely engaged. I have the e-force and switched to 10% overdrive balancer and 1/4 larger idler (pulley for better belt wrap on the supercharger) 1/2 inch larger belt (102.5) put the tensioner right where it was before the changes. So if I would have changed just one I could have gotten away with same belt but it would have put the tensioner a max tension.
To Belt size
