C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Cracked LS7
Old Jul 11, 2017 | 07:01 PM
viper8u2's Avatar
viper8u2
Default Cracked LS7
Cracked my cylinder 3 wall about 3 weeks ago, finally getting over things and getting things rebuilt. Wasn't doing anything special when it gave out. In fact, I didn't even know anything was wrong until I went to leave and smoke came out of my exhaust. Thought it was probably a head gasket. Old build was stock LS7 bottom end, heads redone, A&A Vortech V3-TI, AR headers, Ron Davis Radiator, etc
The car put down 630 rwhp and 560tq with 7# of boost (was trying to run safe until I had a forged bottom)
Anyways, I have a new Concept Performance LSR block coming and debating on some things for the new build.
Just wondering what others are making for power with similar specs, it is a summer toy and I am not tracking it but do like some spirited runs. I am wondering what the max HP guys have been able to do with straight 91 pump gas. Thought about ethanol but like I said really looking for reliability (as much as I can get with a modded car) and no hassles with meth etc
what have you guys done for that balance? I would like to shoot for 800rwhp, but probably thinking I need to be running meth or e85 etc
DRM is doing a full forged blower motor now for me
Mike
Old Jul 11, 2017 | 07:06 PM
Unreal's Avatar
Unreal
You will need meth, or flex fuel/e85 for higher power. 91 just won't have the octane to safely do what you want. If you had meth on the old setup, it probably would be alive today.
Old Jul 11, 2017 | 07:11 PM
Patriot Six's Avatar
Patriot Six
Yes, you will definitely need meth with 91 octane. I made 750whp on a Mustang Dyno with a forged LS7 (10:1 compression) with a V-3Ti and 3.4 pulley on 91 and meth. Car also had a mild blower cam and ARH headers.
Since then, I have installed the new A&A secondary drive with 8 rib. With the stock sized balancer and 3.47 pulley, I gained 2 lbs of boost. This time on 93 octane and meth, it made 837whp on a Dyno Jet.
Old Jul 11, 2017 | 09:07 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agree with previous posts.. more octane, more power, less broken stuff.
Old Jul 12, 2017 | 11:13 AM
BoostedC3's Avatar
BoostedC3
Can't go wrong with Ethanol! Make sure you test the station you get it from however and its not coming in at something like E50
Old Jul 12, 2017 | 11:14 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Test? Psst, get a flex fuel sensor setup and let the ECM deal with it.
Old Jul 12, 2017 | 11:19 AM
BoostedC3's Avatar
BoostedC3
You can defiantly do that and the ECM will keep you safe but with a lower octane the computer will pull power out. Regardless of flex fuel, lower the octane will result in lower power. My local station actually came in at like E90 last time we checked
My car will be going Ethanol very soon. Not to hijack but any preferred kit for flex fuel?
Old Jul 12, 2017 | 11:26 AM
Unreal's Avatar
Unreal
DSX kit, the original, best quality, support, and Dave rocks.
Old Jul 12, 2017 | 07:09 PM
viper8u2's Avatar
viper8u2
thanks for the comments, this is new territory for me so I will need to discuss with my shop. so what meth kit are folks using these days if I go that route? Are you guys running meth and e85 conversions together?
Old Jul 12, 2017 | 07:18 PM
Unreal's Avatar
Unreal
Alky control
Yes plenty of people run meth and e85 together.
For 700-750rwhp, one or the other is more than enough. For 1000+ both can be helpful.
Old Jul 13, 2017 | 04:13 PM
neverstop's Avatar
neverstop
meth is no brainer. imo should be the first mod after the blower for everyone
Old Jul 15, 2017 | 04:29 PM
stevieturbo's Avatar
stevieturbo
You can easily make good power on 91....just dont expect to do it with a high CR.
If using 91 is a necessity...then just build to suit.
If you can add octane/detonation suppression by other means then you can choose to use a higher CR.
Either way it's just about building the right package for your needs.
Old Jul 16, 2017 | 06:36 PM
viper8u2's Avatar
viper8u2
well was down at the Street Machine Nationals all weekend and had a chance to talk to a lot of folks. Seems E85 Flex is the way to go. Going to look into that more. I need to figure out what to do for my fuel system, Not sure if the folks building my motor will be doing the e85 so they will probably be tuning to pump 91 then I will bring it to another shop that has the flex setup. Any recommendations on fuel system?
Old Jul 16, 2017 | 06:48 PM
stevieturbo
It would be pointless building a setup to specifically run 91...then run E85.
The two can allow vastly different end results, and take the initial build in very different directions.
ie, E85 will want a high CR...91 will definitely not.
if you're wanting to run a combination of both, then either you will need to know how much ethanol is in there, or whatever controls you are using will need to ensure you can never run too much boost etc when there is no ethanol in the fuel.
Old Jul 17, 2017 | 01:24 AM
neverstop's Avatar
neverstop
e85 is amazing stuff and vastly superior to 91 obviously and if you have it locally but seriously just 91 pump gas and a methanol kit can easily get you 800+ whp. I'm making 900whp with 91 and dual methanol and been very reliable with 9.75:1 compression. e85 makes the fuel systems pretty serious which can get very complex on these cars, if you're ok with making just 800whp near term I'd just go with simple alky control meth kit and run pump gas and a ECS or A&A external fuel system. e85 is great but not necessarily needed and a top notch FORE fuel system is expensive and seems like a lot of people take time to get them perfect or sacrifice reliability. e85 is better but imo not absolutely necessary and always something you can do later. the difference on my car between 680whp and 860whp was absurd so I bet you'll be happy with 800whp for a bit and can always go back and upgrade fuel system for e85 later and then just have both meth and e85. just my $0.02
Old Jul 17, 2017 | 09:48 PM
viper8u2's Avatar
viper8u2
appreciate the input guys, made a few calls today and got a few opinions. to make more than 750-800 I would probably need to jump up to the YSI, that combined with everything else for flex/e85 is quite the jump in funds that I don't really have now. I will get the A&A external fuel system and it was recommended to me to go with the Jam Cam by Josh @ A&A and probably tune for pump 91 now until I can do the rest late
Old Jul 18, 2017 | 07:07 AM
Unreal's Avatar
Unreal
Anything past 800rwhp gets into a $40k+ build if you want to do it correctly.
To Cracked LS7
Old Jul 18, 2017 | 09:44 AM
neverstop's Avatar
neverstop
this is very true.
a meth kit is like a few hundred bucks and seems crazy to not put one on there at least given what you have into the build. the octane of 91 is just not good for these cars past 650whp imo. I would not feel good driving one of these cars past 650whp on pure 91 octane anyway. If you really go down that path i'd at least put a can of torco in each tank of gas.
Old Jul 18, 2017 | 08:44 PM
speedz06's Avatar
speedz06
I want to warn you to check the block before buying a sleeve if you plan to fix that cylinder.
mine cracked #3 just like yours and looked like a small imperfection but once the liner was out we found the block cracked in the same spot. This can be avoided though.
Good luck with your new build.
Old Jul 19, 2017 | 08:44 AM
viper8u2's Avatar
viper8u2
it went through the water jackets
Already have a new block, concept performance LSR
JE Pistons will be 9.5:1
Jam cam
Etc
Thanks for the feedback/info
