Remove head gasket
Jul 30, 2017 | 11:57 AM
Remove head gasket
What is the consensus on cleaning heads gasket off the engine block. Iron block?? Running boost.
Jul 30, 2017 | 12:17 PM
I believe the consensus is that is is a good idea to clean off old head gasket.
Are you asking about ways to clean it?
Jul 30, 2017 | 12:42 PM
Yeah kind of vague. Depends on the year but most of the newer ones don't require a ton of work to get clean I usually run a razor blade across to remove the rest of the silicone left behind. I don't use any real pressure and then brake clean or lacquer thinner to wipe it off. If luck would have it and its had a set of graphite gaskets I do the same procedure, its just a lot more work. I NEVER use the sanding disk that I've seen some ppl use. GL!
Jul 30, 2017 | 12:43 PM
Quote:
Originally Posted by
Unreal
Yes, After taking off the old gasket what's the best technique to remove the remaining residue??
Jul 30, 2017 | 03:12 PM
Elbow grease with a razor/plastic scraper, and a cleaner.
Jul 30, 2017 | 03:31 PM
Unreal
The scrapper got 90% off, but can't get the rest off. If i use scotch brite if comes off but i was told not to use it???
Jul 30, 2017 | 04:06 PM
I wouldn't let a scotch bright or any abrasive touch the surface.
Jul 30, 2017 | 06:28 PM
St. Jude Donor '15
Razor and brake cleaner and a lot of elbow grease
I would not let scotch brite anywhere near it
Jul 31, 2017 | 06:57 AM
schpenxel
thanks
