pat G custom blower cam, ecs 1500 kit
Hey Guys,
I've been getting a few parts for the ls3 gs manual. I was wondering if anyone was running anything similar, just so I could get ideas on what to expect as far as power and sound. also if there is anything else that I should upgrade now as eventually it will have a novi 1500 ecs kit.
stock it dynoed at 375/394
parts going on as soon as my headers from maryland speed lol. going on 4 weeks.
660 btr springs, titanium retainers
ati stock diameter harmonic balancer
custom pat g blower cam 222/238 .615/.615 lift 155+4 lsa
lg 1 7/8 th super pro headers 3 inch xpipe and zr1 mufflers.
thanks
thanks
You should add an Alky Control meth kit to the list. Should make good power. Not sure how you plan to drive it, but a clutch and drag radials would be a good addition. Good luck with the build.
Good info, My tuner said he always pins the crank on cars that will be getting supercharged. I do plan on running meth and a r888 later down the road. any guesses on power while its NA?
My guess is around 450 in NA form. That cam is very similar to my blower cam and great for a FI set up, but not very aggressive for an NA build. Cam will have great driveability, though.
Do you have any idle clips? I'm a little scared that this cam may be too small and have no lope.
I don't have any idle clips and I won't be near the car for about a week. It has a decent lope at idle, but not crazy. I wouldn't want it too aggressive, especially for a blower cam. That cam will make good power down low and hold power up top and drive close to stock. I'll try to post up an idle video when I can.
It won't have much of a lope, but you will hear it has more than a stock cam.
Mine is close to your specs: VR PD-1 cam with 223/239; .610"/.623"; 118+4* and it has a nice mellow lope to it and makes good power.
Here's what my car sounds like idling with the NPP exhaust closed:
EDIT: Your cam may be slightly more "choppy" than mine, because although you have 1 degree less intake duration, your lobe separation angle is -3* over mine (I'm assuming that your stated LSA/Advance of "155+4" should be "115+4"?). I doubt anyone would be able to discern the difference though.
Mine is close to your specs: VR PD-1 cam with 223/238; .610"/.623"; 118+4* and it has a nice mellow lope to it and makes good power.
https://youtu.be/LTIbVBZYH_o
yes you are right. I meant 115*. Thank you for your clip. Would you guys recommend going with an intake or just wait and save the money? I will probably be N/a for a year or two. I was thinking about the halltech mf103 but I have yet to see actual dyno sheets from individual people
Agreed with CI
Sorry for the late response. Here is a 223/239 116+2 with catless ARH headers and stock exhaust (open).
https://youtu.be/5l1e5mVXVtE
