LSx Boost Happy intake manifolds
#121
Former Vendor
Yes should have zero issues on c6 vette.
c5 vette i need customer to supply rails and inj for me to insure cowl fitment, otherwise my default rails to use will need to notch cowl on c5 only
#122
Former Vendor
My conversation between Steven Rankin (owner of 42 Autosports and tuner of Roho car) and Roho
Car's prior best was 9.2 at 155, I'll get exact prior best time slip and post it in a bit
#124
Billet valley plate, new valve covers, and steam vent kit installed ready for the intake. Fuel rails are sitting next to car. Just waiting for this bad boy to show up.
#125
Also...make sure you have the Holley #534-224 fuel rails ordered or in your hot hands and hex head cap screws for the intake bolts (I think 5mm shorter than throttle body bolt). You'll have to change your inlet pipe too to accommodate the 15 degree angle of the new throttle body position. Fit is excellent by the by....
#126
Fuel rails have been here for a few weeks.
What hex head cap screws?
Shouldn't have to touch the intake pipe, as it has enough flex in couplers to accommodate that, if not I have a hump hose to flex.
Steam vent is just to vent the rear of the heads, for high HP applications. Lets air out that can form when coolant boils/etc. Good for high HP applications.
#127
I'm going to use the OEM LS9 TB part #25828560 intake hose (accordion) to fit the Goertz intake downward angle to my LG super ram air intake. The LG is a very rigid intake and doesn't move much, makes it more challenging to fit the TB up to it if the TB is at an angle. I have the OEM LS7 accordion to try also, but the LS9 has about 15 degrees built into it and looks like it will fit.
Link to LS9 TB accordion:
https://www.iamgmparts.com/oem-parts...YtMmwtdjgtZ2Fz
The bolts that come with the holley rails do not fit the bosses of the G1 intake, I'm told they are M6.
#128
I thought the same with my inlet pipe....but it ends up being a touch shorter than any coupler I can lay my hands on so I'm doing a custom pipe. Yours might be closer...but figured I'd give you a heads up.
#129
Deleting what sensor? No sensors were deleted.
#131
Holley LS valve covers, tall ones. Had the same ones before in short. No idea why I went tall besides maybe one day do a shaft rocker, but same thing I had before. Just wanted to clean up since my old ones have 1/2 fittings welded on, and new setup will have a different routing so not needed.
#133
Received 1,194 Likes
St. Jude Donor '15
Does that steam vent kit use solid tubing or hoses? I can't tell in the pic
Looks nice
Looks nice
#134
Former Vendor
Attn
Anyone with a older design Ltx vette manifold.
We're issuing a voluntary recall.
The large top plenum surface area causes a bit more stress on the top welds than expected.
You will be given the option to either have your manifold braced or just upgrade to a newer design intake where this is no longer an issue.
We don't always get stuff right but we stand 100% behind our product and our name.
#136
#137
ICT billet. Got it off amazon but you can buy it direct too. You need to add the oil pressure sensor adapter if you want to keep oil pressure sensor.
#138
My experience the one time I tried direct port was at the end of a run or in between shifts, the meth was being pulled through the nozzles but it wasn't atomized so it created a condition where the fuel puddled in the intake runners and the air-fuel was excessively rich.
What plans are in place to avoid these issues?
#139
if the nozzles are in the intake there must be check valves in the system, or a solenoid to control flow.
Aquamist make nice little nozzles with check valves built in, this also ensures no lag in the system as the valve is right at the point of spraying.
#140
Originally Posted by Turbo-Geist
Are you manual or auto? I'm curious about which nozzles you are running and if you have any check valves in the system?
