C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
help with my meth/iat setup.
Old Sep 22, 2017 | 11:44 PM
southspeed's Avatar
southspeed
Default help with my meth/iat setup.
so I'm installing a ls3 ecs kit on my ls2 car. I ordered an ls3 maf and the caspers harness to make it work. I was gonna just put my meth pre maf and use the iat function in the maf but tune using SD. My kit is used though and has a hole for meth already cut right up close to the throttle body. Should I have that hole welded up and go about my plans or just scrap that idea and get a solid pipe from intercooler to TB and just put an iat in post meth? If I do it that way how do I wire the IAT in?
Old Sep 23, 2017 | 09:38 AM
Six-Gun-Todd's Avatar
Six-Gun-Todd
Just break out the two IAT wires and use the hole by the throttle body for the individual IAT sensor. It's always good to spray meth on the IAT to tune in a safety margin in case the pump fails or what not.
Old Sep 25, 2017 | 10:03 PM
southspeed's Avatar
southspeed
man this place has gotten slow.
Old Sep 26, 2017 | 09:17 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I think it's more the time that you posted. Six gun's response would work fine if you did not want to spend the money for a new duct, but of course a new one would be a cleaner install.
Old Sep 26, 2017 | 09:22 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Could do IAT in intake, after TB, then use the hole that's already there for meth (or the cleaner way like Doug mentioned is to just order a tube with no MAF at all and add whatever you need). I like putting meth as close to the intercooler as I can and the IAT as close to the engine as I can personally
Old Sep 26, 2017 | 01:19 PM
darknit's Avatar
darknit
I run a lingenfelter ls3 maf on my ls2...
Got 2 casper harnesses, 1 breaks out the iat from the maf, and the other converts ls2 maf to ls3 maf...
i drilled and tapped an iat only sensor into the neck of the intake manifold, sensor is in path of meth...
I mounted 2 meth nozzles into the lingenfelter maf housing after maf sensor...
Old Sep 26, 2017 | 03:53 PM
southspeed's Avatar
southspeed
this looks like the way I'm going. ls3 maf with a capers harness with the iat breakout and single nozzle meth between the maf and the iat.
To help with my meth/iat setup.
