C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel Pump Check Valve
Old Sep 28, 2017 | 04:07 PM
bartsky's Avatar
bartsky
Default Fuel Pump Check Valve
Hey guys I have a new to me blown 08 coupe with a Maggie MP112. I think it has a Walbro fuel pump. If I start the car as one normally would, it turns over too long before starting. However, if I prime it first by holding the start button 5 secs prior to engaging clutch, it starts perfect every time. It has a Magnavolt booster as well. Is this the fuel pump check valve failing? Thanks for any help.
Old Sep 30, 2017 | 11:35 AM
darknit's Avatar
darknit
i have the exact same problem with my aftermarket racetronix pumps... I put a checkvalve on my order when I placed it, but racetronix removed it from the order stating that their pumps hold prime... They were wrong... sounds like quite-a-few companies aftermarket pumps have this problem... I'm gonna add a check valve to my fuel system someday down the road, sick of it taking 2-3 times to crank....
have heard that some aftermarket fuel injectors or lack of proper o-ring sealing at fuel rails can make this problem worse....
Old Sep 30, 2017 | 12:22 PM
Mike's LS3's Avatar
Mike's LS3
When you hold down the start button there is a 2 second prime time (oem tune) for the fuel pump.
I had the same issue, if I held the start button down for a few seconds the car would start up. Once started, the car ran fine. When I shut down the engine while in my garage (all quiet) I actually heard the fuel drip back into the fuel tank (1/2 tank or less of fuel). It sounded like the car was taking a ****. This would be a good indication that the check valve failed. I replaced the fuel pump and all is good!
Old Oct 2, 2017 | 09:45 AM
romandian's Avatar
romandian
do you guys have aftermarket regulators? these dont hold the pressue like a stock one.
Old Oct 8, 2017 | 08:17 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Im about to go with a walbro in tank pump as well....hmmmm
Old Oct 8, 2017 | 09:42 PM
Unreal's Avatar
Unreal
It isn't a pump issue as much as the siphon setup bleeds off. Just part of the Corvette fuel system. Adding a check valve doesn't really help because it still bleeds down though the jet siphon
Old Oct 8, 2017 | 10:20 PM
C U IN REARVEIW
So,my car sits for weeks at a time....would I have to prime pumps every time (walbro pump)?
To Fuel Pump Check Valve
