C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel system problem and to the next level
Old Oct 3, 2017 | 10:47 AM
n_brio's Avatar
n_brio
Default Fuel system problem and to the next level
Today i have 2005 c6 m6 with ttix kit and my fuel system is fore innovation hangar with 2 walbro 450 an8 feed and return with bosch motorsport 1300cc. (I have 4 bar grund pressue = 1400cc)
I have not taken it to a dyno but my boost is around 16 psi max and my injector duty cycle is 83%
I use e85.
In the winter my plan is to forge the engien and turn the boost up to maby 25 psi
My concern then is that i think im running out of fuel.
If i rise the pressure to like 5 bar i think i will run out of fuel pump /flow.
What is the sheapest way to solve this problem?
Can i set one more pump in tha feed line? or do i have to buy new injectors again
Old Oct 3, 2017 | 11:46 AM
Unreal's Avatar
Unreal
Figure out the issue. That is more than enough fuel to max out that kit. Easy 1100+rwhp of fuel.
Old Oct 4, 2017 | 01:51 AM
n_brio's Avatar
n_brio
I did forget, its on e85
Old Oct 4, 2017 | 11:40 AM
Unreal's Avatar
Unreal
Even so, that is plenty of fuel to max out that kit on e85. I would check to see if both pumps are working and fuel pressure is steady.
Old Oct 9, 2017 | 10:23 AM
n_brio's Avatar
n_brio
I did found something strange when i checked my fuelpressure.
My fuel pressure is bouncing between 4.7 and 5.2 bar whene the engine is turn off and i have a jumper insted of the relay making the pump on all the time.
https://files.fm/u/msqqmkk4#/view/20...33514.mp4;play
My setup is fore innovations dual hangar walbro 450 AN8 feed and return
1 pump on all time and secon on hobo switch.
borsch motorsport injectors 1300 and magna fuel MP-9925
what can cause this bouncing? i can understand if i have unstable vacuum but i have the same problem when engine turned off.
Old Oct 9, 2017 | 06:58 PM
Unreal's Avatar
Unreal
Bad regulator?
To Fuel system problem and to the next level
