C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Edelbrock e-Force expectations?
Old Nov 7, 2017 | 06:44 PM
BlindSpot's Avatar
BlindSpot
Originally Posted by darkknight91
ofcourse, so all the pulleys are on the same belt. if you spin the blower more, youre not only spinning the blower more, youre spininng everything else on the belt more as well.
This is incorrect.
The DRIVE comes from the crankshaft and the harmonic balancer diameter. The DRIVEN is every other device. Since the RPMs originate from the crankshaft, it's (HB) diameter, as a proportion to every other driven device on the belt, determines each driven RPM.
If your theory was correct, then if you spin the SC faster, you must also be spinning the crankshaft faster too as its pulley is also on the belt.
The alternator RPM does NOT change in its relationship to the RPM coming from the crankshaft. Only the SC spins faster, BC only it's pulley diameter was changed in relationship to the crankshaft.
