C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Help on a&a kit install
Old Nov 9, 2017 | 02:12 PM
LS3_Alex's Avatar
LS3_Alex
Default Help on a&a kit install
im currently folkwing the how to on a&a site and for the oil feed and return line I’m trying to find another solution. The feed line goes to a replaced galley plug port underneath driver side head and it says to drill and tap the oil pan for the return. I don’t want to do that will it be ok to use a oil plate adapter that goes above the oil filter?
Old Nov 9, 2017 | 05:08 PM
EnviedC6's Avatar
EnviedC6
No, you cannot use a plate adapter. That side is pressurized and will cause backup to your SC. You are going to have to go to the pan or go scavenger pump and pump it back to valve cover..
Old Nov 9, 2017 | 08:40 PM
Blue by U's Avatar
Blue by U
really not a big deal, with right tap. Make sure you measure clearances for fitting twice, tap once.
Old Nov 9, 2017 | 10:26 PM
LS3_Alex's Avatar
LS3_Alex
Thanks for the input fellas looks like drill and tap it is
Old Nov 10, 2017 | 07:07 AM
Unreal's Avatar
Unreal
Or swap blowers for a self contained one so you don't have to mess with feed or return.
Old Nov 10, 2017 | 09:30 AM
LS3_Alex's Avatar
LS3_Alex
I think the market would be hard to sell just a v2 head unit
Old Nov 10, 2017 | 03:16 PM
Tech's Avatar
Tech
The engine oil units can handle more RPM. It would have been worth checking. I think A&A also takes headunits for trade in.
Old Nov 10, 2017 | 04:08 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
It’s not hard to drill and tap the pan. Not a reason to change blowers for sure.
Old Nov 10, 2017 | 04:17 PM
camarokidz28's Avatar
camarokidz28
Vortech mentioned that they do that to me too.
Old Nov 10, 2017 | 04:50 PM
Blk 08 C6's Avatar
Blk 08 C6
Tap that pan.not that hard to do.YSI here.Pat G. tuned.lol
Old Nov 10, 2017 | 05:54 PM
Unreal's Avatar
Unreal
Agreed it is easy, just throwing that option out if someone is really set on not drilling/tapping.
Old Nov 11, 2017 | 10:28 PM
darknit's Avatar
darknit
what trim is your v2 ? I have a v3-t (self contained)
Old Nov 11, 2017 | 11:04 PM
LS3_Alex's Avatar
LS3_Alex
i drilled and tapped it. And I have a v2 t trim head unit I planned to go turbo in the future is why I really didn’t want to set on drilling and tapping but I could re use barb out of oil pan for future turbo set up
To Help on a&a kit install
