C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Procharger....
Old Nov 10, 2017 | 05:30 PM
Blue by U's Avatar
Blue by U
Default Procharger....
What vendor is best to deal with on prochargers? As in price, tech, and customer service?
Old Nov 10, 2017 | 06:19 PM
Nino S's Avatar
Nino S
I started with a P1SC 6 rib and that thing ate belts left and right until I went with a A&A bracket and a 8 rib direct drive set up and had no issues. I still have the same 8 rib DD and A&A bracket with my F1X set up now. There are a lot of options out there for FI, what are your goals with the car? Built motor? stock? do not boost a stock LS7 lol
Old Nov 10, 2017 | 08:23 PM
Blue by U's Avatar
Blue by U
car is supercharged right now with built motor. Just thinking about changing set ups.... was wanting to know who everyone deals with on procharger?
Old Nov 10, 2017 | 08:42 PM
Nosferatu333's Avatar
Nosferatu333
On Internet it’s brutespeed. Talk to bob.
Old Nov 11, 2017 | 05:58 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Message me what you need.
Old Nov 11, 2017 | 08:59 PM
StingrayRebel's Avatar
StingrayRebel
another vote for a&a's procharger bracket, it's leaps and bounds better than the one I originally had on the car... they can probably get you a procharger headunit as well and I have also heard good things about brutespeed... what kit do you have right now?... depending on what you have you might be able to get away with just a new bracket and blower
Old Nov 11, 2017 | 11:32 PM
Blue by U's Avatar
Blue by U
A&A new style bracket with ysi-b.....
Old Nov 11, 2017 | 11:47 PM
StingrayRebel
do you just want more power than the ysi can make?... what you have should be a solid setup but if you really want to change you can get an a&a procharger bracket and a headunit and keep everything else... maybe go with a 10 rib and secondary drive as well if you don't already have that
Old Nov 12, 2017 | 11:18 AM
Blue by U's Avatar
Blue by U
yes. I got 10 rib and secondary drive. What problems do people have with Procharger bracket? I always hear people have problems, but not what the problems are.
Old Nov 12, 2017 | 11:25 AM
StingrayRebel
belt slip, the tensioner and the way it's designed is not the best... 10 rib on an a&a bracket with a secondary drive should be a very solid setup with both your ysi or a procharger
Old Nov 12, 2017 | 12:32 PM
Blue by U's Avatar
Blue by U
I have a friend that is running all procharger stuff, and he has no problems. It seems that he is able to get his belt tighter than I can. When I tighten my belt super tight, the belt actually hits itself and rubs, but it might be too long of a belt. I am using the size that Josh at A&A recommended, for my pulley sizes. I have also noticed that on max effort ysi set ups that many are using a 2.70 blower pulley, and I am running a 2.75. Does the 2.70 allow use of a shorter belt? I am running a 100529 green belt, with 10% OD Ati balancer.
Old Nov 13, 2017 | 10:24 AM
algZO6's Avatar
algZO6
i have a 2.70" and run the 530RPM and that sucker is tight. i saw 28 psi in 2700" DA.
Old Nov 13, 2017 | 10:45 AM
Blue by U's Avatar
Blue by U
530 8 rib is same length as my 10 rib 529, by rpm chart. What balancer? Yours a innovators west? Mine is a 10% od Ati.
Old Nov 13, 2017 | 10:49 AM
algZO6's Avatar
algZO6
yea, an IW 8"
Old Nov 13, 2017 | 11:00 AM
redcycle13's Avatar
redcycle13
I've had really good luck with the Cartek Procharger bracket.
Old Nov 13, 2017 | 12:48 PM
EX1's Avatar
EX1
I went with the Dallas Performance bracket. Go with that one or the A&A IMO.
It terms of pricing, I got a quote from Bob @ Brutespeed after I saw his name come up a few times. It was only like $50 less than the prices advertised everywhere. I ended up getting the best deal from calling Colorado Speed after seeing one of their threads on here. I would call them or shoot a PM to Fran @ RPM.
Old Nov 13, 2017 | 07:38 PM
Unreal's Avatar
Unreal
Call Fran. He builds the fastest procharged vettes. He knows what works.
A&A with their 10 rib and DD is the way to go.
Old Nov 14, 2017 | 10:47 AM
Mrbluedevil88's Avatar
Mrbluedevil88
I'm curious if anyone has tried Prochargers new direct drive kit.
Old Nov 14, 2017 | 10:53 AM
Unreal's Avatar
Unreal
I know CPR tried the procharger 12 rib race kit with DD and it was a **** show. Didn't work at all. Landed up swapping to A&A 10 rib and now perfect and 1450+rwhp.
To Procharger....
