C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
NX window switch question
Old Nov 29, 2017 | 08:30 AM
Cockroach's Avatar
Cockroach
Default NX window switch question
When hooking up a NX window switch instructions direct you to splice into the RPM signal wire, I think this is pin 48 [white wire] on the ecm/pcm. The question I have is where is the easiest location to tap into this wire. Thanks
Old Dec 4, 2017 | 03:21 PM
NitrousOutlet's Avatar
0NitrousOutlet
Former Vendor
This is where we recommend getting TPS and Tach Signal from:
Tach: Passenger Side Main Coil Harness Connector- Top row of wires, 2nd wire from the left.
TPS: Purple (Rising) or Green (Falling) wire on TPS sensor
Old Dec 6, 2017 | 03:02 AM
MikeSVT04's Avatar
MikeSVT04
I started with the purple wire. Could not get a good signal. System would turn on and off throughout the rpm range. Switched to the green wire on the passenger side coil pack. Works perfect.
To NX window switch question
