C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Npp mufflers and boost question
Old Dec 15, 2017 | 09:51 PM
c6 monkey's Avatar
c6 monkey
Default Npp mufflers and boost question
One of my Npp mufflers developed a nasty rattle. After some research I found out the baffles can blow out. I'm at 14# of boost. Before I go and get other Npps and possibly have the same result is like to get your opinion on weather or not staying with the same mufflers is ok. I have the mild to wild hardware and like the adjustability of the sound. For those that are boosted and have Npp please chime in on the durability. Thanks!
Old Dec 15, 2017 | 10:04 PM
Detoxx03's Avatar
Detoxx03
Mine have been holding up great
Old Dec 15, 2017 | 10:44 PM
DubsAndSubs's Avatar
DubsAndSubs
One of mine developed a rattle shortly after I boosted it. I just kept driving the hell out of it, and it eventually fixed itself. I'm assuming the baffle wedged itself somehow, but it hasn't rattled since.
Old Dec 15, 2017 | 11:10 PM
c6 monkey's Avatar
c6 monkey
Detoxx, I'm glad your having good luck with yours. Badass car by the way. Dubs, your not the first to say the rattle went away. I'm torn cuz I've got different ones I could get for $350 I'd have to get them installed too. The rattle is getting a lot worse. Maybe something will wedge or break loose. Anybody else have any experience with this?
Old Dec 15, 2017 | 11:20 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
No issues with mine at 20lbs of boost. I usually have them open when pushing it hard though.
Old Dec 16, 2017 | 11:05 AM
c6 monkey's Avatar
c6 monkey
I'm sure it doesn't help to have hollowed out cats and the fiberglass removed from the mufflers. Realcanuck, 20 lbs is rockin it. How long have your guys npps been on and ok?
Old Dec 16, 2017 | 01:44 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Been on 5 years from 500 to 1000 hp builds. No cats either most of that time.
Old Dec 16, 2017 | 01:48 PM
Dimewise's Avatar
Dimewise
Wow I completely forgot I had a bad rattle under light throttle (parking lot speeds) until I read your post. I'm boosted and it fixed itself also! Granted mine rattled prior to boost most likely from hitting a pot hole.
Old Dec 17, 2017 | 08:26 PM
Unreal's Avatar
Unreal
My stock mufflers with NPP had ~18-20k miles of hard 1000+hp driving. No issues.
Old Dec 17, 2017 | 08:35 PM
Meh Vette's Avatar
Meh Vette
This happened to my NPP setup after headers with 9 psi. I had a local guy cut them open and do the muffler mod, he then stitch welded the cracks back up and reinforced the front/back walls with angle iron. No issues since the repair work was done.
Old Dec 18, 2017 | 08:43 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
No issues on mine either, mine open once near boost though. Not using the controller, connected directly to vacuum source
Old Feb 6, 2018 | 11:51 AM
needcheese's Avatar
needcheese
I had rattles in mine before boost.
https://www.corvetteforum.com/forums...p-muffler.html
Member Atomic C6 added to my post on what he did to fix his. I did this myself. I have had no issues with mine since.
Old Feb 6, 2018 | 12:12 PM
BoosTTed C6's Avatar
BoosTTed C6
Had that set up for years. 16lbs of boost. Usually ran the NPP open but, on 4 occasions that I can recall, I made a WOT 2 - 4 gear pull with it closed. No muffler issue as a result.
I do know that in really high horsepower/boost applications (1xxx whpr cars), the NPP blades have been bent open by the force.
Old Feb 6, 2018 | 04:18 PM
Unreal's Avatar
Unreal
Never seen them bent on OEM system.
Old Feb 6, 2018 | 04:20 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Me either.!!'
Old Feb 6, 2018 | 06:02 PM
scottg's Avatar
scottg
Only 600rwhp in last 4years with added hp, no problems, 10lbs boost.
Old Feb 6, 2018 | 10:26 PM
BoosTTed C6
To my understanding, 1 Swt Ride bent a set on stock Z06 cans then did it again on a set of Fusions. He may have been using the M2W controller in both scenarios. I may be wrong but I’ll let him weigh in.
To Npp mufflers and boost question
Old Feb 6, 2018 | 10:32 PM
Unreal's Avatar
Unreal
I know he killed a set of fusions or two, and I killed a set of fusions, along with 5-6 other people, but in 20k miles with stock NPP at 1000+ never an issue. Now the fusions lasted ~800 miles or something silly.
Old Feb 7, 2018 | 02:51 PM
1SwtRide's Avatar
1SwtRide
Correct - the fusion blades folded from the exhaust heat. The OEM blades held up. The OEM muffler cans, well that's a different story. They bulged out so much that we had to replace them with non-npp cans. I'm still in search for a long term fix that include npp/mild-to-wild functionality. All ears if anyone has suggestions
Old Feb 7, 2018 | 03:05 PM
Unreal's Avatar
Unreal
Ear muffs that you put on or off in the cabin.
Only ~500 miles on my "fixed" B&Bs. Will tell if they survive after first runway event with them in March.
