Just finish my build lsx 427 with ysi. 2.7 upper 8in lower. Made 21psi. Problem is peak power is at 5900 and fell for pretty bad after that. Cam was degree by engine builder. Tuner thinks blower is just done. Anyone who has maxed out a ysi what does it look like on the dyno.
Reason: Add graph
Fueling afr was 11.5 across the board. Timing was 18 degrees we tried 20 and it lost 2 hp and still peaked in same spot. Leaning toward the valves floating if it's not the blower. This was on a mustang dyno. So 920 on it is about 1050 on dyno jet
YSI on a 402. 19.5 lbs and less timing than your running. Valve float would show as fluctuating on the dyno. Something doesn't seem right there, but would need a log to try and see what.
Tuner wasn't saving logs. So I don't have any. I'm thinking it's either the blower or float. I talked to Josh at a and a he thinks blowers done. Might try stiffer springs and go from there.
How can a tuner not be saving logs to look at after a pull ? Thats just dumb.
Doubt it's springs. Don't see how blower could be done, but I guess anything is possible. I would still think belt slip first. Would have thought more than 21 PSI with a 2.70 pulley, but there are a lot of variables to boost so don't know for sure.
He was logging the pulls making changes then logging the next run. Just not saving them. It's got big cam ported heads and it's a 427 so boost will be lower. Honestly I thought 21 was a lot from what I see on 427 ysi builds. It made 17.5 with air filter on and 21 with it off
If he's using hpt, and a version greater than 3.0 he has the logs in %userprofile%\Documents\HP Tuners\VCM Scanner\Logs assuming default install location. Every time you stop a log it autosaves.
