C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Single turbo ls2?
Old Jan 10, 2018 | 05:21 PM
SteveSierra's Avatar
SteveSierra
Default Single turbo ls2?
hi guys I’m looking to get my ls2 single turbo’d.
How would the ls2 block hold up to the extra power?
Old Jan 10, 2018 | 08:55 PM
Ant-Man's Avatar
Ant-Man
Yeppppp you'll be fine way less stressful on the internals than a blower.
Old Jan 11, 2018 | 10:51 AM
SteveSierra
Really, I always thought a turbo was more strain as it’s sudden power whereas blower is smoother constant power
Old Jan 11, 2018 | 11:46 AM
Ant-Man's Avatar
Ant-Man
I'm no means an expert but I did a research as well and a lot of people said the turbo comes into power smoother and it easier on the internals since there's not a belt attached to it causing more tension on it. I know it's especially true for coyote motors and that's how their opgs get damaged most times.
Old Jan 11, 2018 | 12:45 PM
CK@UPPCOS's Avatar
0CK@UPPCOS
Former Vendor
Having put together and tuned more than a handful of LS2 Twin Turbo cars I say you have nothing to worry about. If you're open to the idea of twins we have the perfect kit for you!
http://uppturbo.com/parts/upp-c6-cor...win-turbo-kit/
If you're interested we'd be more than happy to talk to you about installing and tuning it. Just give me a shout!
Old Jan 11, 2018 | 02:59 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Biggest thing is you aren't using power from the crankshaft to turn the blower when running a turbo setup. It's mostly driven by heat that would have been wasted otherwise, so it's more efficient. Same amount of cylinder pressure is going to end up make more power at the wheels on a turbo setup because none of that energy is being used to spin the blower. There's still exhaust back pressure on turbos, etc., so it isn't like 100% free power but turbos are def. more efficient than blower setups.
My point is you can basically have lower cylinder pressures on a turbo setup (which should be easier on the motor) and still make the same amount of power. On a supercharged setup you'd have to make some extra to cancel out the power you're using to spin the blower.
I'd say a PD blower is probably the closest thing to sudden power that you can get on these cars. They'll make max boost pretty much instantly at about any RPM. Centri's only make like 1/2 of max boost at 2/3 of max RPM. So if you see 15psi at 6K RPM's you might see 7.5psi at 4K.
Turbos do make a ton of torque down low, just have to keep it under control with a boost controller of some sort. It's fun having the flexibility turbo setups offer though, IMO anyways. Packaging has always kind of sucked in C6's, just not enough room to easily add turbos.
Old Jan 11, 2018 | 07:39 PM
stevieturbo's Avatar
stevieturbo
And just how much extra power would that be ?
To Single turbo ls2?
