C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Edelbrock E-Force replacement tensioner pulleys? (LS2)
Old Jan 12, 2018 | 01:17 AM
Triple88a's Avatar
Triple88a
Default Edelbrock E-Force replacement tensioner pulleys? (LS2)
Hello,
I have a 2007 6.0L Corvette with the E-Force Supercharger kit that shredded a belt. From the looks of it, the bearings on the auto tensioner idler pulley and that other pulley on the same bracket are bad (the third pulley that came with the kit (page 19 in the link below) also has a little wobble. Where do i get replacement pulleys? I called in but the support guy I talked to was next to useless.
Yes the pulley is different size than the original LS2 pulley. The pulley in the kit is a bigger diameter than the stock.
Page 20 on the installation manual.
http://www.edelbrock.com/automotive/.../1000/1594.pdf
​​​​​​​Thanks for reading
Old Jan 23, 2018 | 08:42 PM
speedz06's Avatar
speedz06
Hi I used a 100mm dayco you can find in the dayco catalog. Edelbrock is useless and the parts list that comes with installation manual is wrong too.
email me if you need help
Old Jan 24, 2018 | 01:22 AM
Triple88a's Avatar
Triple88a
Hello there, thanks for the response.
I ended up posting on the edelbrocks forum and found the right parts there.
CARQUEST by DaycoIdler Pulley
Part No 89007
Part No 89009
Old Jan 24, 2018 | 12:56 PM
speedz06's Avatar
speedz06
Part No 89007
Part No 89009
OK good glad you found it.
To Edelbrock E-Force replacement tensioner pulleys? (LS2)
