C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Dewitts EOC drops oil pressure.
Old Jan 18, 2018 | 11:51 PM
LethalTT's Avatar
LethalTT
Default Dewitts EOC drops oil pressure.
So long story short. New engine with 10295 pump and 10% increase red spring.
Oil pressure with EOC setup with dewitts:
40 cold
30 @180 degrees
6600 rpm 42 drop to 39
WTF?
Remove oil cooling line from oil filter block and put block off plate:
50 cold
42@180 degrees
6600 rpm 61.
I did research and found a thread on here about a "special" 898 "modded" dewitts line. WTF?
Looks exactly like my stock lines. What is modded in it is a relief valve? Anyone seen this before? It also states it will still cause a 7 psi drop. What is going on here? What else should I run if anything?Makes me not want to run a cooler. I'm going to be pushing this motor to 7500 rpm. My feed for turbos is a sandwich plate between the oil cooler and filter housing.(now block off plate from 5.3 and filter housing.
https://www.summitracing.com/parts/dwr-898
Old Jan 19, 2018 | 01:24 PM
Mike Farris's Avatar
Mike Farris
I saw the same regarding the Dewitts EOC. My motor must be looser so Ive been debating switching to a 10296 pump.
I think that 898 line kit is just a c6 line kid modded to fit a c5. Im pretty sure Dewitts recommends and sells just a c6 oil cooler line kit that comes stock with the bypass. They dont recommend the aftermarket blocks without bypass valves.
Old Jan 19, 2018 | 02:07 PM
ImprovedRacing's Avatar
ImprovedRacing
Supporting Vendor
Which Dewitt's oil cooler are you using?
Old Jan 19, 2018 | 08:46 PM
LethalTT's Avatar
LethalTT
Shortened Model: 1139105B
Old Jan 19, 2018 | 08:48 PM
LethalTT's Avatar
LethalTT
I have lines that I used for my Z06 cooler that I ran to the dewitts after I had to remove Z06 cooler due to space constraints. I have dual spal fans as well. With scavenger pump for turbo lines. Not alot of room. My intercooler is big
Old Jan 21, 2018 | 08:14 AM
darknit's Avatar
darknit
I have a lingenfelter high volume oil pump(did not install high pressure spring) and cut-down dewitts and have very high oil pressures... 60's cold idle and 70's reved up cold... 40's warm idle and 60's reved up warm... every once in a while I notice a drop of oil on concrete where car was parked and its coming from a fitting at the dewitts eoc, probably the o-ring... no complaints at all about my setup...
Old Jan 22, 2018 | 07:36 PM
Mike Farris
Bearing clearances have a lot to do with oil pressures. Not surprised there are different experiences.
To Dewitts EOC drops oil pressure.
