NX wiring help
I have a nx nitrous kit that I am going to install but I need some help
-Its a single nozzle kit w/ purge(going to run a small shot so I doubt I need a lc unit to pull timing)
-nx 18959 TPS WOT digital switch
-fuel pressure safety switch
The diagram included with the kit is simple but I am not sure how the 18959 unit gets wired into the system using a fuel pressure safety switch. Can someone help? Maybe a diagram?
The FPSS usually goes inline from your signal wire. 12v -> WOT switch -> FPSS -> solenoid.
