C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
PCV valve LS3 Dry-sump location e-Force?
Old Mar 22, 2018 | 04:30 AM
mikecronis's Avatar
mikecronis
Default PCV valve LS3 Dry-sump location e-Force?
I think there's a fixed, positive crankcase hose that's re-assigned upon an e-Force Edelbrock Stage-1 kit on the LS3. (kit #1574)
My installer overfilled the oil by 2 quarts and my oil-pressure was pegged at 80 PSI after 100 miles of "dyno" testing. I dumped the oil and put the right amount in using the dry-sump dipstick test method as-proper and now the oil pressure is accurate.
I wanted to see if a PCV valve was fouled or if oil got into the e-Force valley area, the ventilation hose to the air-filter was dry, thankfully, not spitting oil, etc. I've been told there is no PCV? Anyone have a pic of where I should look?
Old Jun 23, 2019 | 01:32 PM
Jaycajun's Avatar
Jaycajun
You will get blow by with a blower. Get a Mighty Mouse catch can and the problem is solved.
