C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Over sized balancer for boost
Old Apr 7, 2018 | 09:33 PM
curtisb23's Avatar
curtisb23
Default Over sized balancer for boost
Thinking about doing a 12% overdrive balancer on my new setup and am wondering if this will cause any issues with power steering and the charging system. Thanks
Old Apr 8, 2018 | 01:51 AM
CI GS's Avatar
CI GS
Lots of people use overdrive balancers for boost without any issues, including myself. I have an IW 10% OD.
Old Apr 8, 2018 | 08:33 AM
Unreal's Avatar
Unreal
That being said, once you goto a direct drive, it no longer matters as they OD part is not driving the accessories. I would think about doing a DD at the same time.
Old Apr 8, 2018 | 08:39 AM
curtisb23's Avatar
curtisb23
I already have a full 8rib kit on the car didnt realy want to switch to a Dd realy unless I realy needed to
Old Apr 8, 2018 | 09:36 AM
helga203's Avatar
helga203
Just curious what your pulley setup is now? Can't pulley down on the S/C side any more?
Old Apr 8, 2018 | 10:34 AM
curtisb23's Avatar
curtisb23
I changed the whole setup from a sbe ls2 v3t stock size balancer 3.47 blower pulley all 8 rib to a built lsa 6.2 ysi 2.85 an I was going to change the lower to help with some belt slip if I get any
Old Apr 8, 2018 | 12:36 PM
GeneSch's Avatar
GeneSch
What 8 rib set up are you using? Where did you get the 8 rib pulleys?
Old Apr 8, 2018 | 06:30 PM
helga203's Avatar
helga203
Im almost certain you are going to need a DD system with that pulley size. Your going to have to isolate the S/C pulley belt. I would do the OD crank damper.
Old Apr 8, 2018 | 07:53 PM
curtisb23's Avatar
curtisb23
I got them from a&a and the balancer is a ati
Old Apr 8, 2018 | 09:49 PM
Detoxx03's Avatar
Detoxx03
Full 10 rib system with OD ATI balancer here and it works fine
Old Apr 9, 2018 | 11:55 PM
winters97gt's Avatar
winters97gt
ATI balancer, Dallas Performance DD, and A&A secondary drives on 2 of my many setups. You need a secondary drive with a YSI and 2.75 upper.
Old Apr 10, 2018 | 02:54 PM
EnginerdVT's Avatar
EnginerdVT
I was going to tack on to the OPs questions that if there is an OD balancer added, is there anything that would keep you from going 10% vs. 15%? I'd think that, to a point, the larger OD balancer would increase the size of the blower pulley for increased surface area contact and with DD it wouldn't affect the accessories... I'm about to go through the same trade(s) and am deciding between 10% OD or 12-15% OD...
Old Apr 10, 2018 | 05:17 PM
Unreal's Avatar
Unreal
Who makes a 15% over? That is one issue. Other is clearance with subframe. With a 10% over there is barely room to put a belt on.
Old Apr 10, 2018 | 06:44 PM
curtisb23's Avatar
curtisb23
I talked to ATI and they have stock size, 9% and a 12% od.
Old Apr 10, 2018 | 06:45 PM
curtisb23's Avatar
curtisb23
the subframe would need lowered you think?
Old Apr 11, 2018 | 01:08 AM
CI GS's Avatar
CI GS
The subframe clearance issue can be taken care of by spacing the engine cradle away from the chassis by using something like the LPE spacer kit.
But then the problem becomes the water pump pulley to balancer clearance, which is tight even with the 10%.
IW actually makes a ~8.35” o.d. balancer, which has a actual pulley diameter of 8.25”, IIRC. That’s what I was told when I ordered my 10% OD IW, which has a pulley diameter of 8” and a slightly larger overall o.d. I was tempted to buy the larger version, but the sales rep at IW told me that he thought I would need to switch to an aftermarket WP that had a smaller pulley, so I bought the tried and tried 10% OD version.
Old Apr 11, 2018 | 06:28 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You will end up doing the direct drive with that setup so save time and money by doing it now.
Old Apr 12, 2018 | 08:30 PM
EnginerdVT's Avatar
EnginerdVT
Innovators West sells 10%, 12% and 15%...
Old Apr 16, 2018 | 08:00 AM
Six-Gun-Todd's Avatar
Six-Gun-Todd
This^^^^^
Don't mess around, just do the A&A secondary drive with the proprietary balancer and laugh at belt slip.
To Over sized balancer for boost
