C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Low Boost Solution
Old Apr 11, 2018 | 03:39 PM
VetteArts's Avatar
VetteArts
Default Low Boost Solution
Running heartbeat for a year now on 08 C6. Pulley is .84 that had a boost 8 psi. For a gew months in garage and workshop, it shows 6 psi. I changed the belt and checked intake and all seem fine but still runs same low boost. I have another pulley .81 but prefer fixing the problem rather going around it. What possible solutions should I consider!
Old Apr 11, 2018 | 04:19 PM
old motorhead's Avatar
old motorhead
I'm assuming you mean 84mm pulley. You should have a hell of a lot more boost than 6psi unless you're up in the clouds, have a very nasty cam, very open exhaust....and ported heads. How are you set up?
Old Apr 11, 2018 | 06:41 PM
ls1wolf's Avatar
ls1wolf
With the stock 96mm pulley and my blower cam I was still at 6psi. Something is way off if your using an 84. You should be at 9-10psi
Old Apr 11, 2018 | 08:30 PM
EuroRod's Avatar
EuroRod
You may have a pressure leak.
Old Apr 12, 2018 | 08:30 AM
Unreal's Avatar
Unreal
First of all, forget XXX pulley=XXX boost. That doesn't mean anything.
Weather, air filter, heads, cam, headers, exhaust, elevation, motor size, etc etc etc etc etc all effect boost levels.
If it was 8psi, and now went down to 6, check the weather, air filter, leaks, and belt for wear and proper tension.
Old Apr 13, 2018 | 06:34 AM
VetteArts's Avatar
VetteArts
Set up is:
Cam
225/230
.617"/612"
114 LSA
kooks headers, corsa x pipe and cat-back (no cats). I use the air intake and filter that came with blower package. Alkey meth. Still at same city. And hp did not show a notable drop, 608 rwhp.
The thing is I had ~8 to 9 psi on same 84mm pulley and set up. Few months back it has been max 6.
I saw 11psi on 81mm in the past also.
Ok, I re-tuned and changed MAF but that is irrelevant I assume.
Old Apr 13, 2018 | 06:38 AM
VetteArts's Avatar
VetteArts
How do I do complete leak check?
Old Apr 13, 2018 | 07:36 AM
Unreal's Avatar
Unreal
Build a leak check, hook it to blower, pressurize system, and either feel, listen, or spray with soapy water to find leaks.
Old Apr 16, 2018 | 08:28 PM
Blue by U's Avatar
Blue by U
Dirty air filter, or boost leak. Check clamps, couplers, or just do pressure test.
To Low Boost Solution
