anyone have any experience with nano nitrous?
i can get a kit at a good deal i was wondering if it was worth the extra hassle in filling up extra bottles?
current setup lsx 454 200 shot direct port with dual 10lb bottles, i know il have to rejet the fuel side , will i see much more power. or just the ability to use more out of the bottle.
I use it in several of my cars. Works great, I spray for longer periods than most because I run the Texas Mile. Filling the bottles is no big deal.
nice! did you have to re jet your fuel side like they say? i have a stand alone cell i was wo dering if i would just be able to up the pressure to make up for rhe difference in n20.
You can get the nano bottles filled at any paintball field or scuba shop. Should be less than $10. I'd refill them every time you refill the nitrous bottle(s).
I have 3000 nano. I don't think you would need to up your pressure, but use a larger fuel pill. I think it's 10% larger to compensate.
It cost me 5 dollars to fill my bottle at a paintball shop. I bought a new adjustable psi regulator and set it at 1050 psi. The nano regulator is made by ninja.
You want to get a hold of 1SwtRide or Doug from ECS.
ECS did the set up on 1SwtRide's Z06 (the car is a monster - fully built motor, big blower, power glide, big nitrous set up). He has the nano set up, installed by ECS. Doug could steer you through the set up and John could tell you about ownership and ease of operation, etc.
I ran it on my dry setup, one of the main benefits is consistency, and being able to simplify my nitrous setup electrically, definitely will have to add fuel. on my first initial test hit, it lean out almost a full point.
