C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Is a cam worth it?
Old 04-20-2018, 03:04 AM
SteveSierra
SteveSierra's Avatar
Default Is a cam worth it?
hi all looks like I’m going to have to replace the harmonic balancer.
Question is while the garage is doing that is it really worth changing the cam? Looking a at a btr turbo stage 2 as I’m fitting a single turbo kit very soon.
I don’t want to do rods as garage said that will be a much bigger job but would the cam involve a lot more work also and is it worth doing if it’s just the cam without rods?
Old 04-20-2018, 10:12 AM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Goals?
Old 04-20-2018, 10:21 AM
SteveSierra
At first I want to get to around 700whp but the only reason I mention a cam is because the balancer is being replaced so would save time/money if I ever decide to cam in the future
Old 04-20-2018, 10:24 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Don’t need a cam at all for that goal, up to you if you want to do it now while it’s easier to get at. Def better to do now vs later. But isn’t necessary at all.
Old 04-20-2018, 12:35 PM
SteveSierra
Can a cam be installed on its own or do you have to do springs and rods also?
Old 04-20-2018, 12:37 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Depends on the cam. You keep saying rods, I’m assuming you mean push rods? They take 5 mins to install. I’d change them and springs while you’re at it if you do cam
Old 04-20-2018, 12:39 PM
SteveSierra
That’s what I thought but the garage I asked said it’s an engine out/rebuild to do the rods
Old 04-20-2018, 12:40 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Then quit calling them rods and call them push rods so they know what you’re talking about
Rods do require engine out. Push rods don’t.
Old 04-22-2018, 01:30 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Worth it is always a personal thing. That is a financial decision if the rewards are worth the cost. Only you can answer that.
For most people, yes a cam is worth it.
Typical cam kit should contain
Cam
Springs, Retainers, seats, locks, seals, shims, etc
Push Rods
Timing Chain
Gaskets
Possibly oil pump, tensioner, gears, ARP bolts, seals.
No idea why you are talking about rods unless it is push rods. Rods are not an issue, as pistons, heads, etc all fail before rods.
Old 04-22-2018, 03:41 PM
Blk 08 C6
Blk 08 C6's Avatar
do the cam your in there.stage2 blower cam here.
Old 04-22-2018, 08:43 PM
c5wolf
c5wolf's Avatar
Do the cam and lifters. Check pushrod length
Btr stage 2 here
Old 04-23-2018, 09:18 AM
BT03mach-1
BT03mach-1's Avatar
getting the balancer off is most of the hard work installing a cam.
Old 04-24-2018, 12:51 PM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
We can build you a custom profile for your setup. Don't just pick a off the shelf cam.
Old 05-21-2018, 06:52 AM
SteveSierra
Any rough ideas how much extra hp a cam would produce?
Old 05-21-2018, 04:08 PM
vrybad
vrybad's Avatar
Totally depends on the cam.
Old 05-24-2018, 06:00 PM
SteveSierra
Was looking at either a btr stage 2 turbo cam or an mti cam
Old 06-01-2018, 01:01 PM
SteveSierra
Right I’ve found s good garage now that will do the balancer/cam/turbo install
Can anyone help with the spec of cam that would work for my setup please
BW 369sxe turbo
80lb injectors
bap
de cat
stock ls2 engine
fuel 93 pump gas
would like stockish idle, not a fan of the massive choppy cams but a tiny bits fine.
To Is a cam worth it?
Old 06-02-2018, 10:39 AM
C U IN REARVEIW
C U IN REARVEIW's Avatar
BW 369sxe turbo
80lb injectors
bap
de cat
stock ls2 engine
fuel 93 pump gas
Put in a phone call to Brian Tooley
Old 06-02-2018, 03:24 PM
Pete2k_Z28
Pete2k_Z28's Avatar
IMO springs are always a good idea when going FI. If you're doing springs, you need hardened pushrods. And if you already have the balancer off, pushrods out, and springs in, you're probably better than half way on the labor anyway. So for 400 bucks for a cam and a few bucks more labor, you have a cam. There, I just gave you your justification
Old 06-12-2018, 04:32 AM
SteveSierra
Lol thanks.
Move spoken to tick performance and they’ve suggested their stage 1 cam, 227/231 .625"/.605" LSA114+4. I suppose the only slight frustration is the stage 1 is only rated to give 35-55whp, not massive gains for what will cost around $2000 all in.
Quick Reply: Is a cam worth it?
