C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
breaking up under boost
Old May 31, 2018 | 07:18 PM
russ472's Avatar
russ472
Default breaking up under boost
I have developed an issue when under hard acceleration the engine starts breaking up under boost. I haven't done any logging in a while so i hooked up HP tuners and thought I would find a lean condition. Well its not running lean but when it starts breaking up it is showing up to 5 degrees of knock retard. Can a misfire show up as retard?
I have been running on 93 lately and haven't refilled on corn to see if it makes a difference. How many miles are you guys getting on a set of plugs? I might have 15k miles on mine.
Old May 31, 2018 | 11:11 PM
StingrayRebel's Avatar
StingrayRebel
what plugs and gap?... I had the same thing happen to me after switching to e85 and the weather got cool, it would break up at 5k and the log showed 5-6 degrees of knock but no lean condition and it drove perfectly fine otherwise... my plugs were gapped at .035 and I closed them to .030 and it solved the problem
Old Jun 1, 2018 | 04:03 PM
russ472's Avatar
russ472
i want to say I set the gap at 35 when they were installed, but that might have been a year ago. Makes sense though. ill pull plugs tonight and check.
Old Jun 3, 2018 | 08:56 PM
russ472's Avatar
russ472
finally got a chance to check the plugs today. gap was at .40. closed them up to .30 and problem went away.
thanks
StingrayRebel
awesome
Old Jun 3, 2018 | 10:24 PM
droptopsnake01's Avatar
droptopsnake01
Was about to say. Sound like blowing spark.
To breaking up under boost
