C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A&A kit... Head removal
Old Jul 8, 2018 | 07:27 PM
ssbowtie1's Avatar
ssbowtie1
Default A&A kit... Head removal
Hi all, I'm looking to get an A&A kit installed and was wondering what it would take to remove the LS7 heads once the kit is on? Reason being is I plan to remove the heads next year and install MS90 valve guides.
Old Jul 8, 2018 | 08:34 PM
Ant-Man's Avatar
Ant-Man
A tensioner lock bolt, and some bracket removal. Maybe adds an hour extra. I've taken off my direct drive and blower multiple times, I'm not gonna say it's a breeze but it's doable.
Old Jul 8, 2018 | 09:48 PM
Unreal's Avatar
Unreal
Basically need to remove the blower, but heads should be addressed first prior to the blower. No reason to scatter the motor and cost you $10k+ when you can deal with it now and add blower next year.
Old Jul 8, 2018 | 09:50 PM
ssbowtie1's Avatar
ssbowtie1
My heads are done but I only went with PM guides. I'm sure it's only a matter of time before they wear out so I'm planning MS90s in the future. The joys of LS7 ownership...
Old Jul 8, 2018 | 09:51 PM
Unreal's Avatar
Unreal
Unless you didn't do it correctly, no reason they will wear again. Enjoy it. If you got a decent setup, no reason to touch them or take them off again unless you like burning money.
Old Jul 17, 2018 | 08:27 PM
MTPZ06's Avatar
MTPZ06
A simple inspection down the road while tell you whether its even necessary. Did you go with a radical cam or something? If so, its probably not boost friendly to begin with.
To A&A kit... Head removal
