What size injectors are some of you running with E85 and a YSI? I have a 402 CI motor, 10:1 compression with ID1300's making about 18 PSI. Injector duty cycle is reading 130% at redline, 100% by 5700. Car isn't running lean.
After speaking with A&A it sounds like their stage II fuel system isn't enough for my application Going to add a third external pump and see if that helps.
how much power you making to wheel? im running a 427 lsx 9.5:1 YSI combo on there set dual set up no issues
as mentioned check fuel pressure at top rpms to see if it still holding.
I maybe way off but when you have 1000+ and stock ecu only supports 60lb on tables you lie on the size as you know by doing half if or more .in this case has to be more than half.
My car would always show 140-160% duty cycle, so ovvisobvi that isn't possible. Always figured it was off from the in accurate ifr tables.
Weird stuff for sure.. since it just uses inj PW in the calculations, which should be after all the other math that uses airflow/AFR/inj flow rate, etc. is used to calculate it, I didn't think IFR would make the calculations wrong. But there's probably more going on in the background of calculating IPW than I know or something that is screwing up the #'s.
Oh well, whatever works
