C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
P1sc record?!?!?!?!
Old Aug 24, 2018 | 04:41 PM
11oldmanride's Avatar
11oldmanride
Default P1sc record?!?!?!?!
I have an 11 m6 car and I'm curious what the fastest vette is with a p1 on it manual or auto I don't care.
mines been 9.89@140
Old Aug 24, 2018 | 05:41 PM
underconstruction's Avatar
underconstruction
Killer ET man. I have a baby vortech V3 Si with m6
best et was 10.2 @ 145
Old Aug 25, 2018 | 10:55 PM
73DBG's Avatar
73DBG
What else do you have with your P1 set up? I’ve been curious as to what it’s best capabilities are, I’ve got a P1 as well still doing **** to correct the build the previous owner did. What size rib? Blower pulley? That’s a sick time, I’m guess your also a damn good driver?
Old Aug 25, 2018 | 11:56 PM
JetstreamGS's Avatar
JetstreamGS
A lot of folks don't realize that these baby blowers are very efficient. 9's rowing the gears is no joke. Keep up the good work!
Old Aug 26, 2018 | 12:45 AM
73DBG's Avatar
73DBG
I hear that! I’m just curious as to what specifically he has done, how much boost? Stock or built bottom end....the details, high 9’s with a P1 is awesome, again I feel it’s safe to assume he’s a hellava driver.
Old Aug 26, 2018 | 08:52 PM
11oldmanride
Only makes about 12.5psi, 6 rib 3.4 pulley,stock size crank pulley..it does have a Texas speed built short block with ported ls3 heads but I think it would’ve been fine on the stock bottom end if I wouldn’t of had a mishap with the meth kit on a previous setup
Old Aug 26, 2018 | 09:54 PM
73DBG's Avatar
73DBG
Wow 12.5 PSI! Looks like I’m going to have my bottom end built as well, I have IW 10% OD pulley and 8 rib kit to go back with, replacing 6 rib kit, 3.7” blower pulley and a custom grind blower cam from cam motion. What cam are you running and how much power did 12.5 psi make ?😳
Old Aug 26, 2018 | 10:31 PM
11oldmanride
Btr ls3 supercharger cam.. and it hasnt been on a dyno
Old Aug 26, 2018 | 10:32 PM
11oldmanride
Old Aug 26, 2018 | 11:20 PM
c6 monkey's Avatar
c6 monkey
Impressive ET for sure, congratulations. I'm gearing up for the track. What are the specs of your tires?
Old Aug 26, 2018 | 11:27 PM
73DBG's Avatar
73DBG
Correct me if I’m wrong OP, but I was under the impression from what I’ve read or been told, 12.5psi on a P1SC1 is a lot of boost? Before my car went down for the rebuild and we tuned it I was making 4.5psi on 6 rib kit with 4.25” blower pulley. I think I’m correct in saying the boost was low or lower because the cam the prior owner had was doing most the work and blowing boost out of the exhaust? I’ll be fine if I make 7-8 psi on the rebuild.
Old Aug 26, 2018 | 11:36 PM
11oldmanride
just camaro ss 17” wheels with Hoosier 28x10 slicks on them
Old Aug 26, 2018 | 11:38 PM
11oldmanride
they rate it at like 30 psi max boost I think but that would be on a very restrictive engine obviously..but I am actually overspinning mine so it is completely maxed out
Old Aug 27, 2018 | 08:00 AM
Patriot Six's Avatar
Patriot Six
You'll make less boost on an LS7 due to the larger displacement.
Old Aug 27, 2018 | 09:33 AM
g23crawler's Avatar
g23crawler
That's impressive! Noticed the Iowa plates, do you go to I29 often?
Old Aug 27, 2018 | 01:46 PM
11oldmanride
I’m almost 5 hours from there but I was there for the first no prep this year and got runner up in the stick class..I plan on goin to the no prep at the new track in Onawa in a couple weeks
To P1sc record?!?!?!?!
