UPP TOP MOUNT T4's.....Finally!
Former Vendor
Hey Guys,
I know it's been a long time in the making but we wanted to make sure we try to address all the concerns in one go with this new setup. And we are now happy to announce that we have full framed T4 capabilities on our Z06 (dry sump) twin turbo systems!
With this we have increased the cold side piping slightly, and these will be with recirculating wastegates now (this particular customer wanted external dumps). These are now available, and we should hopefully have this full build buttoned up here shortly with some nice 4 digit numbers to back it up!
CK
CK
Is this basically the same set up as before but with some tweaks? It looks like one wastegate is on the turbine housing and one is on the manifold? Same turbos as before or what is the specs on them? Same price point around $10k?
Former Vendor
CK
Are the turbos supported anywhere besides the headers? what size are turbos are those in the pics? That intercooler looks smalls.. All in all this looks really good
Former Vendor
The turbos are only supported by the manifolds (same as always); with our thick sch10 piping we've never seen an issue. The intercooler in the pic is our standard option, and we have the upgraded Tredstone 9" intercooler available.
Former Vendor
Former Vendor
Former Vendor
Former Vendor
Below, same as we would if it were a wet sump. Honestly not sure you could tap into the pan above the tray could you? I thought those windage trays set pretty high up in comparison to the pan
