C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Check gas cap at half tank
Old 11-17-2018, 08:51 PM
slow goat
slow goat's Avatar
Default Check gas cap at half tank
I have a strange issue with my blown C6. I recently started driving it again since building the motor and supercharging it. I also installed a ragin racing twin aeromotive 340 fuel system. I'm seeing now that once I get near the halfway fuel mark, I trigger a check gas cap light on the dash. If I fill it up, the light goes away. I've driven as low as 1/4 tank remaining so I don't think there is a problem with the fuel crossover. Has anyone encountered anything like this?
Old 11-17-2018, 11:07 PM
silvrhand
silvrhand's Avatar
had the same problem, replaced my gas cap with a new one and the problem has gone away. It was coming loose and the gas smell in the garage was strong, after I replaced it all gone.
Old 11-17-2018, 11:25 PM
slow goat
slow goat's Avatar
I replaced mine with a new Stant unit. The problem returned.
Old 11-19-2018, 10:25 PM
slow goat
slow goat's Avatar
Bump
Old 11-19-2018, 10:28 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Means you have an evap leak somewhere.
Old 11-20-2018, 08:20 AM
slow goat
slow goat's Avatar
As I read your response, I remembered that I deleted the evap canister and forgot to cap the metal end coming from the firewall. I just capped it. Let's see if that makes a difference. Thanks.
Old 11-20-2018, 11:11 AM
Unreal
Unreal's Avatar
That would do it.
Old 11-22-2018, 03:24 PM
slow goat
slow goat's Avatar
After capping it, I got the service fuel system error and the fuel level reads empty. Should I remove the cap, or keep it on and wait for it to clear?
Old 11-23-2018, 10:31 AM
slow goat
slow goat's Avatar
Up to top
To Check gas cap at half tank
Quick Reply: Check gas cap at half tank
