C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ls7 vs other options. boost.
Old Dec 29, 2018 | 02:27 PM
_Wayne_'s Avatar
_Wayne_
Default Ls7 vs other options. boost.
My goal is 1000+ whp I'm between a supercharged setup or turbo set up right now. So my current situation is I have a wet sump ls7 forged bottom end with APR studs and all the good stuff (unsure of the parts) currently in it the car with an A&A kit sitting at 800ish whp. The timing chain broke and a lifter collapsed and after fixing that it has 20 psi at warm idle and metal shavings in the oil. I am going to pull the motor this week to refresh it (new bearings make sure the crank, rings pistons ect are in good shape), but should I put the refreshed block back in the car or would it be better to go with a different option to handle the 20+ psi of boost I'm going to throw at it? and just put the ls7 in my c5. As always thanks for the help.
Old Dec 30, 2018 | 11:42 AM
HouseS2k's Avatar
HouseS2k
factory sleeves?
Old Dec 30, 2018 | 12:26 PM
_Wayne_'s Avatar
_Wayne_
Yes factory sleeves
Old Dec 30, 2018 | 12:47 PM
HouseS2k's Avatar
HouseS2k
Yes factory sleeves
not to sure the oem liners will handle 20psi. I’ve read of people going to 15-16. Not sure how long they lived. I know there’s companies that can press in stronger sleeves.
Old Dec 30, 2018 | 01:12 PM
_Wayne_'s Avatar
_Wayne_
That’s what I was concerned about. New sleeves will run around 2500 installed (estimate from what I’ve read) plus the machine work it’ll probably need I’m almost to a different short block
Old Dec 30, 2018 | 01:19 PM
MOTOWN Z's Avatar
MOTOWN Z
That’s what I was concerned about. New sleeves will run around 2500 installed (estimate from what I’ve read) plus the machine work it’ll probably need I’m almost to a different shirt block
For that kind of coin I would get an LSR block and build around that with confidence
Old Dec 30, 2018 | 01:56 PM
_Wayne_'s Avatar
_Wayne_
Had not considered the lsr but that looks like an option. I was thinking a sleeved 5.3, bored and stroked to a 427, the lsr, or maybe go with an iron block or lsx block
Old Dec 30, 2018 | 02:05 PM
Unreal's Avatar
Unreal
LSR block starts around $4500, then add machine work/etc. A "cheap" LSR setup may come in around $9-10k. While they are great blocks for 1000-1200rwhp, would be a tough pill to swallow for what you want.
Iron blocks are strong, but are heavy, and like to run hot.
I would not run what you have, and the little things are what make a difference. Stuff like upgraded head studs, gaskets, cooling modifications, etc etc make a motor at 1000hp last 20k+ miles as opposed to a dyno queen. At this power level, it is about keeping the heads on, and pistons happy. Even then plan on pulling motor every 15-20k for a full refresh.
Old Dec 30, 2018 | 02:28 PM
_Wayne_'s Avatar
_Wayne_
My current block does have 1/2” head studs, studded mains and has made 900 in the past. I’m just concerned about longevity of the block at that high of power and boost. I’d rather pull it, out new bearings in it and drop it in my other car and keep it at 700 >. So I guess I’m between a iron block or something like a sleeved ls block. I know running 1000hp+ means more mantaince and down time and I’m okay with that!
Old Jan 1, 2019 | 08:10 PM
Shortpersonbk's Avatar
Shortpersonbk
Cylinder liners dont care if you run 20psi or 80psi. Pressure in manifold is irrelevant to cylinder pressure which is what is cracking sleeves in combination with knock ect.
But +1 for not pushing the stock liners that far power wise especially when you already invested so much into the other parts. During you refresh you should just have the block sleeved.
Old Jan 4, 2019 | 04:14 PM
ForceFedC5's Avatar
ForceFedC5
I highly recommended against purchasing an LSR block. My engine builder ordered two (1 for me) and the block was drilled for the wrong size head studs, the other block was also incorrect, it was shipped with no water jackets. The engine builder and I attempted to get both blocks replaced and Concept Performance stated they would be shipped within 2 weeks. That never happened. As far as I know, my engine builder is still stuck with those blocks. There were also some machining issues and I've heard that Concept Performance is having issues. My recommendation is to stay FAR away
Old Jan 4, 2019 | 07:06 PM
Unreal's Avatar
Unreal
I've had the block for 3+ months. No problem for my builder. BTR got him one quickly with no issues.
Old Jan 4, 2019 | 07:09 PM
ForceFedC5's Avatar
ForceFedC5
I'm glad it worked out well for you, however I still strongly believe possible future purchasers should take my (and my builders) experience into consideration before making a purchase
Old Jan 4, 2019 | 07:11 PM
Unreal's Avatar
Unreal
Sure they should. Plenty of locals running them without issues and didn't have those issues. BTR was a great place to get the block from because they would sort out all those issues, etc.
Old Jan 4, 2019 | 07:15 PM
ForceFedC5's Avatar
ForceFedC5
BTR is a great shop from what I've heard. I'm commenting on the actual mfg not the resellers/builders. I know of a few engines that work well, I also know of a few that did not. Add in the mfg horrible customer service and that's something to take into consideration, thats all I'm stating
Old Jan 6, 2019 | 10:30 AM
stevieturbo's Avatar
stevieturbo
A goal of 1000+ ?
Is that 1001, or far beyond ?
If not too far beyond you're still within the realms of a well built factory block, whether LS3, or preferably LSA or LS9 based.
Or if you must retain 427, then yes some sort of linered block would be an option.
Although if your at 800hp already n/a, that extra 200hp or so via boost is really going to cost a hell off a lot of money, especially with a new motor.
Old Jan 6, 2019 | 11:29 AM
HouseS2k's Avatar
HouseS2k
Originally Posted by stevieturbo
A goal of 1000+ ?
Thats my thoughts. Making a 1000hp and living at 1000hp are 2 very different things. @Detoxx03 has been playing footsy with the 1000whp on his stock bottom end ls3 with a d1x.
To Ls7 vs other options. boost.
Old Jan 6, 2019 | 01:48 PM
stevieturbo
Unless there's a ton of hard racing, making it hold together at or around 1k isnt that hard.
But yes doing it with a SBE is playing with fire.
Old Jan 6, 2019 | 10:53 PM
_Wayne_'s Avatar
_Wayne_
My goal is to be at or slightly above 1000whp. Its a Street/Strip car that'll probably see more street/cruising use than strip. I'm leaning on not doing a 427 and switching to a 370-415 motor
Old Jan 7, 2019 | 12:19 PM
stevieturbo
If the budget is there, a LSA or LS9 based alloy block, stock cube motor would be ideal and a good strong alloy block. Yes you could go iron, but whether you want the extra weight is up to you, and I dont see a factory iron block as an upgrade vs the LSA or LS9, although yes it would be cheaper.
Although deviating from the LS7 will mean complete new engine. ie heads, intake, everything. But LS3 intakes are readily available and perfectly fine for boost.
You could also easily buy a long nose crank for the new motor to retain the LS7's semi-dry sump setup if you wanted.
Or just revert back to a normal wet sump.
For ease of fitment/use etc....the likes of a YSi or similar would be hard to overlook for the goals in mind
