V-15 testing the right way at East Coast Supercharging!!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
East Coast Supercharging has always been about knowing our products, testing our products to their limits and actually knowing what we are taking about in regards to them to best of our abilities. We have always felt it is not good customer relations to make your customers figure out the limitations of your own products because this will most certainly make customers have to keep coming back to you for upgrades as they figure out those limitations on their own. Now maybe we are the fools because that's really not a bad business model if you only care about taking in as money as possible, but if you truly care about your products and customers best interests, we feel it is best to be able to tell the customer exactly where we found the limitations of each combo are so you can reach your goals directly the first time without over spending to do so.
When it comes to the new head units coming out, (which is very exciting btw!) We do not plan on changing that business model. We are going to go through each stage of builds from the mildest this blower can be used at, all the way to the wildest.
We are going to start by reaching the limits of our largest air to air intercooler so those who are thinking of using this headunit on an otherwise fully streetable vehicle with all accessories can see what your limitations will be. From there will go to an Air to water, and from there will go to a full methanol only car with no intercooler.
We have it running on 1SweetRide's (John) C6Z, this car has been mid 8's probably ten years ago and now it is built at a completely different level, yet is a full weight, full accessory street driven vehicle. Basically starting on the ground level, we will post our results as we go. Dynoing is coming, but unfortunately our current dyno can't handle it. Luckily we have a new dyno on order that can handle 3500 HP that will be here soon.
Now this is a proper test vehicle for the new Vortech Superchargers V15. East Coast Supercharging built C6 Z06 powered by a Late Model Engines430ci LSX backed by a ECS Powerglide/9" combo. Listen to this bad boy whistle ready to inhale mountains of air!!!
Turn up the volume and enjoy!!
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
I cannot view the video, what power did it make?
DOUG @ ECS (03-09-2019)
Well I guess he could have thrown him a bone and stated where his dyno maxed out. After all when he first mentioned (which I think was two PRI's ago) this new centri was touted as the "X" killer. So one has to assume the "X" never maxed out his dyno.
Ysi maxed out the same dyno they have on my car, many times, at 1200rwhp. So safe to assume well over 1200rwhp.
1SwtRide (03-09-2019)
We just tracked tuned anything over that anyway so it wasn't much of a problem until a few years ago when making 1000+ HP became so common that it was just impractical to do that all the time. Problem is I swore off roller dyno's a long time ago, our dyno was 83k and the larger version of our current dyno is around 140k if I remember correctly. Luckily now there are a couple of eddy current hub dyno options that are more reasonably priced, so we have one on the way that will arrive in a few weeks that can handle 3500 HP.
As far as being the "F1X killer", I know what the F1X produces CFM wise, and I know what this head unit is capable of, it's simple physics really. Yes it took a little longer to produce than they expected, but if it was easy to produce a blower that can produce what this does while specifically being made to fit in a C5/C6, than everyone would make it. I let everyone know what was coming when it was debuted at PRI a little over a year ago, but unlike our "competitor" I won't bad mouth our supplier for this, you would think he would have learned the first time, but at least this time if he does it won't negatively effect us too like last time.
I have seen an F1X make 1,4-1,500 on a dyno, it would be interesting to see what this makes.
Originally Posted by DOUG @ ECS
As Unreal already stated, our current dyno maxes out right around 1100 rwhp depending on set up and how fast the power ramped in. I have ran it out several times with just a 2200R or X so I wouldn't even bother trying with this head unit. With the CFM it produces it is expected to make 1500 HP, but we have made more power to the tires than all the other head units are rated to at the flywheel, so I guess we'll see soon.
As far as your competitor goes, I don't have a dog in the fight.
Looking forward to the results.
The following 2 users liked this post by BoosTTed C6:
1SwtRide (03-15-2019),
DOUG @ ECS (03-19-2019)
They labeled it is 1500HP capable, but we have always made more to the tire than what they rate their blowers at. I guess under promise/over deliver. When you ask for valute diameter, do you want the outside dimensions or intake/exhaust sizing?
Former Vendor
I would like to know the dimensions for the inducer and exducer, inlet flange od, volute diameter, etc... I have requested this info from Vortech but they haven't let me know yet.
Well got on a dyno with it yesterday, ended up running out of fuel a little earlier than expected so we are working on that now. Going in as a stated earlier I started with the air to air intercooler that was in the car, that is definitely not up to the task with this blower. To the point that I will say don't even bother, and air to water is a minimum. The intercooler in the car is full length and a top of the line core, but it just doesn't cut it. Big pressure drop after and the IAT's were up there.
So we are going to correct the fuel issue and do some track testing, but 30+ lbs of boost is not a problem.
From there I plan to install it on one of my engines on an engine dyno and see exactly what kind of numbers we can put down with it, I will report back when that takes place.
Oh the car we tested it on is a Powerglide car with a non lock up converter, it put down 1000 at 5600 RPM on an 8000 rpm engine. So not really conclusive to it's potential, but I wasn't unhappy either.
The car tested has direct port meth injection, but I shut it off for testing with X85 in there so I can see what the actual IAT's were. We ran out of pump.
What pump and injectors?
Also took some low key test hits at the track, just to get some 8,000 RPM hits on it. Everything did fine so now it's onto the engine dyno next.
Quiky One (05-07-2019)
