C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Is a Max'd Ti really the best street set up?
Old 03-12-2019, 11:13 PM
Podium
Podium's Avatar
Originally Posted by Unreal
Unless you want 950+ no reason to go Ysi besides bragging to friends or showing off at a dick measuring contest.
It is street friendly, just a waste and pointless to run for 750-800rwhp when the Ti will work better.
Thats my thing, I want to make 1k plus but I dont want to spin everywhere I go and get my *** kicked cause I cant hook. From what I have read, 800ish is perfect for a vette thats street driven. Dont want to do a 15inch conversion and drag suspension/
Old 03-12-2019, 11:16 PM
Podium
Podium's Avatar
Originally Posted by algZO6
save your money and use your stock block and crank unless you have money to burn lol
I have a little money I can set on fire lol. Im leaning towards a 383 or 402 with AFR heads and keeping my Ttrim.
Millennium FRC
Millennium FRC's Avatar
Originally Posted by Podium
That was due to poor suspension or poor tires.
I spin mine to 6.8k or so
Not your engine rpm, your impeller rpm. What are you spinning the impeller up to?
Old 03-12-2019, 11:18 PM
Podium
Podium's Avatar
52k I think.
Old 03-13-2019, 12:11 AM
Millennium FRC
.....I want to make 1k plus but I dont want to spin everywhere I go and get my *** kicked cause I cant hook.
Even with slicks, with 1k at the wheels on the street, traction will be very limited. I was running Mickey Thompson Sportsman Pros with 683 at the wheels and could make tire smoke on the highway, no problem.
Old 03-13-2019, 09:21 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
If you want 850+ and hook decent on a street, you want a GTR.
Even 15s and drag radials hooking 1000+ is a chore. On a good street, with fresh tires, aired down, heated up, and on a warm day, you can do it for a few passes.
Plus once you get past 850 reliability of everything goes out the window and cost goes way up.
Old 03-13-2019, 09:34 AM
g23crawler
g23crawler's Avatar
And once you figure out how to hook you find out real quick what the weak link is lol
Old 03-14-2019, 11:21 AM
Podium
Podium's Avatar
i can’t afford 15k transmissions.
Going to stay with the TI. Going to build a nice motor for it. Need to decide on 383 or 402.
Old 03-14-2019, 11:26 AM
algZO6
algZO6's Avatar
neither, stock cubes with a good head on it. strokers on stock blocks like to rock the pistons. trust me, people that have been there done that are giving you good advice.
Old 03-14-2019, 11:27 AM
Unreal
Unreal's Avatar
If you can't afford $15k+ transmissions, you can't afford a 1000+rwhp vette either. I always find that funny, as building a good reliable 1000+rwhp vette is EASY $60k+ in parts. People throw out stuff like that above, and if a $15k tranny is a concern, a 1000+rwhp car shouldn't even be a thought.
Decent reliable vette tranny to hold 1000+ is $15k+ too, and only has 2 speeds and sucks for highway driving. At least a 15k GTR tranny still drives nice.
Old 03-14-2019, 11:28 AM
Podium
Podium's Avatar
That sucks. I was hoping to get some more torque.
Old 03-14-2019, 11:57 AM
Unreal
Unreal's Avatar
Up to you. Trade off reliability for more low end. Just means you spin tires at 50% throttle instead of 70%.
Old 03-14-2019, 09:55 PM
  #33
C U IN REARVEIW
C U IN REARVEIW's Avatar
can an ls2 w/ti-trim,good intake and heads get to 850whp?
Old 03-14-2019, 11:15 PM
  #34
southspeed
southspeed's Avatar
I bet with a manual on e85 it would be close. I watched an ls3 automatic make close to that on e85.
Old 03-14-2019, 11:55 PM
  #35
C U IN REARVEIW
E85 is not very easy to come by around here....I am running methanol dependent though...?
Old 03-15-2019, 12:38 AM
  #36
Detoxx03
Detoxx03's Avatar
Have it turned for flex fuel. You can easily get a drum and full it up im slidell and keep
at your house or get some from Ignite. More than one way to skin a cat.
Old 03-15-2019, 09:57 AM
  #37
algZO6
algZO6's Avatar
i'm sure it would be close. remember, i had the old t-trim on my ls6 with cast trick flow heads and it would run 147 all day in a heavy car.
To Is a Max'd Ti really the best street set up?
Old 03-15-2019, 05:23 PM
  #38
Sergio8A
Sergio8A's Avatar
Maybe , my V3-Si is over spun and makes 720-730whp dynomite on a ls2 SBE. Still more than 100 off though
im sure your T-Trim will make more...
Old 03-15-2019, 11:46 PM
  #39
southspeed
southspeed's Avatar
what fuel? Manual or automatic?
Old 03-15-2019, 11:50 PM
  #40
Sergio8A
Sergio8A's Avatar
me? Or the OP?
Me: E85 plus Meth. 6speed
Quick Reply: Is a Max'd Ti really the best street set up?
