C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Those making 1k plus step inside please
Old Mar 24, 2019 | 07:16 PM
Podium's Avatar
Podium
Default Those making 1k plus step inside please
To those making over 1k. What do you break and how often? Whats your set up? Id like to hear your stories.
Old Mar 24, 2019 | 07:50 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Never break anything on the street. At the track I've broken axles, diff output shafts, and spider gears. Best upgrade that stuff and avoid the aggravation. Avoid wheel hop and chances are good of not breaking.
Old Mar 24, 2019 | 08:02 PM
Unreal's Avatar
Unreal
List would be long, and not sure if that should include all the preventative stuff where things were found on the way out.
Axles, bearings, driveshafts, rear ends, trannys, water pumps, dampers, fuel pumps, meth pumps, valve springs, pistons, rings, bearings, oil pumps, etc etc etc etc. Just put 6-8 weeks a year when the car will be down, maybe a winter and summer downtime, or spring and fall, and $10k or so a year in maintenance and parts. That is what it takes to maintain a nice 1000+ setup.
Old Mar 24, 2019 | 08:07 PM
Podium's Avatar
Podium
Well I do have the winter downtime here in MN
Old Mar 24, 2019 | 08:14 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You're doing something wrong. LOL
In the last 3 years since I stopped going to the track I've had almost no major issues other than maintenance stuff. Redid my heads but that's a wear issue. Normal stuff
Old Mar 25, 2019 | 07:04 AM
droptopsnake01's Avatar
droptopsnake01
Lol. Unreal makes me laugh sometimes.
10k a year in maintenance lol.
Old Mar 25, 2019 | 09:54 AM
Unreal's Avatar
Unreal
Not even joking on that. People who think I am are the ones who try to make a 1000hp car, then let it sit broken forever, and land up selling it for a huge loss. That number is pretty accurate.
Old Mar 25, 2019 | 10:24 AM
g23crawler's Avatar
g23crawler
The car is one thing, but once you have a car to that extreme supporting it is just as hard. If you have a 1k plus car you're most likely not driving it to the track. So at least 3k for a decent flat bed trailer, or 10k for an enclosed. And if you really want to get serious you will be traveling and trying to pull a 24ft enclosed with a half ton sucks. So 15k or more for a decent truck.. And if you have a 1k car you'll probably want to show it off, the events alone are expensive. Just going to Tx2k, $400 event registration, $730 for 4 nights at a hotel, $400 for fuel, $200 for food. So almost 2k just to go run my car 4 times, granted tx2k is one of the biggest events all year but still around $1k to go to Colorado for shift sector. Stuff like that is what ate my lunch, its no fun having a powerful car and not being able to use it.
Old Mar 25, 2019 | 10:41 AM
Unreal's Avatar
Unreal
2-3 sets of tires a year. A $1500-3000 clutch a year. Figure heads come off and motor gone though every 20k miles. Tranny will last ~100 passes if lucky. Axles about that, rears about that. Everything just wears more. Not saying it will be $10k a year, every year for up keep and maintenance, but if you average out the years were it is $15k with the ones where it is $5k, a solid $10k a year is a good point to start with.
Wasn't even including anything g23 just talked about or gas or insurance. That is all extra on top.
Old Mar 25, 2019 | 10:25 PM
playtoy's Avatar
playtoy
i must be doing it wrong also because I agree with you on this.
Old Mar 26, 2019 | 12:28 PM
Shortpersonbk's Avatar
Shortpersonbk
There is also two groups of owners. Some only want to take their big power car out on saturdays or sometimes once a month. Others want to drive it to work 4 days a week and put a 10k+ miles on it a year ect. This combined with simple things like how often you beat on it or how or well will massively change the amount you spend.
To balk at 10k a year to maintain a car you consistently take to the track is shocking. H/C c6 z06 owners are destroying several thousand dollar diffs and trans by the boat load at the track let alone double that power then add in simple odds and ends tires clutches ect.
Old Mar 26, 2019 | 12:31 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Agree... if constantly beating on the car.. and going to track events I would expect everything mentioned. Since I stopped that and just enjoy cruises, and the occasional beating on the street, nothing ever breaks on my car.
Old Mar 26, 2019 | 12:56 PM
Unreal's Avatar
Unreal
That is taking into account having a $5k tranny and $4k diff. Which at 1000+ last maybe 100 passes if you are lucky, before needing to come out for a refresh.
Also that was doing all the labor myself. If you are paying a shop, double that at least. I'm not taking labor into account.
Old Mar 26, 2019 | 05:40 PM
WHITE_SHARK's Avatar
WHITE_SHARK
Depends on many factors, is your usage drag or street or show&go?
For street, you will require regular maintainance provided that you have good supporting mods and high quality performance parts, build and tune.
Also your style of driving one of the main factors and how many times your car will see WOT and how you are beating your car,
Another important thing to consider for example 1001whp car with 18psi is different and require most likely very less maintainance than 1300+whp vette with 30psi for example.
My experience with Ysi A&A setup and 416ci built block , 6speed trans, making 913 on c16 conservative tune, 760whp 91pumb gas,, it was great experience and street use all day,,, spark plugs,,clutch replacemen after a while and thas it,,daily drive it and weekly beat it.
Right now with 26psi making 1150whp on Glide and doing drag racing, this is like a discovery journey which is full of sh... surprises lol
Old Mar 26, 2019 | 06:16 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
The 1000 hp and above is more expensive to maintain A separate problem is most guys can not really handle that much hp and can do stupid
things and cause more problems. I have shown guys how to launch and save their axles, then they go out on the first pass and blow both axles.
I find with some common sense 800 hp can last a season with few issues. Even 800 hp can be too much, if you let your mind wander.
Concentration is the key.
Good luck.
Old Mar 27, 2019 | 09:30 AM
BoosTTed C6's Avatar
BoosTTed C6
At 760 whpr, my car went in for routine maintenance and cost very little to operate the 3000-5000 miles per year I drove the car.
When we embarked on the present build, Doug and Chris at ECS advised that 5-10k would be the annual repair/maintenance budget depending upon how much racing we did. As they have been there and done that many times, I would take their estimate seriously. it just so happens it aligns with Unreal's experience as well.
Take it for what its worth...………..
Old Mar 28, 2019 | 09:22 PM
Podium's Avatar
Podium
I also have to buy a new clutch(1.5-2k), and new injectors$$$$$. I just spent over 2k on both of those last year and really want to try and sell them for a lot less and buy new again. Going to Max out the T Trim and build a motor.
To Those making 1k plus step inside please
Old Apr 5, 2019 | 12:17 AM
Brian.'s Avatar
Brian.
That's an easy one, the BANK ! Break it about twice a year between a promod vette and a 1000+ hp daily vette.
Old Apr 6, 2019 | 03:34 PM
PSSSSSHC6's Avatar
PSSSSSHC6
Are we talking 1000BHP or 1000WHP?
Old Apr 6, 2019 | 03:36 PM
Unreal's Avatar
Unreal
Typically wheel, as we have no clue what BHP is since people don't ever really throw their combos on engine dynos, and throwing stupid figures like 15% or 20% just is dumb and old school.
