E-Force Install Advice?
It is a 554 hp kit and I will be installing a DeWitts radiator and a Racetronix fuel pump upgrade harness at the same time.
I am going to use the Drop-the-Subframe method to get enough clearance to pin the crank. I also purchased a DeWalt 1/2" electric impact to remove the crank bolt. It has about 1000 lb-ft of torque so shouldn't have any problem removing the bolt. Also, going to install an ARP crank bolt instead of TTY bolt.
I will run the stock Edelbrock tune for a couple of weeks but I want to get a dyno tune as I do have headers. The tune is not adjusted for that and Edelbrock won't provide a tune for anything but a stock vehicle.
From what I have read, I will need to also adjust the stock suspension bolts because the extra weight of the supercharger will cause the front to drop about 1/2 to 3/4 inches.
Anything else I need to do?
Thanks.
I don't think my GS lowered more than 1/4" after installing the SC ... Not really noticeable.
Most folks I read reported they were okay with the lower height after the install...
From everything I have read about the install and reviews of the kit, it seems quite straight forward. The kit itself is packaged very well. Came on a pallet in a large box. The large box contained two smaller boxes. One contained the supercharger and rail covers. The other box included everything else.
Will update with pictures soon.
I am located in northern Kentucky just on the other side of the river south of Cincinnati.
On my C5's the Dewitts was great but on my C6Z it didnt work out well at all for a daily driver in the city.
The oem works better in heavy traffic stop and go conditions especially with A/C on. The dual fan upgrade is good but make sure you seal the shroud properly and you have a very beefy relay or even dual relays, solid state if you want to use the computer pwm modulation from factory computer and harness to run the fans AND very heavy grounds.
Furthermore with the bigger fans you may want the HP alternator. See how it adds up?
If I had to do over again I would take the trans cooler out of the radiator and go with a separate trans cooler resulting in more engine cooling capacity in the radiator.
Not sure about your kit but mine is for the LS7 Z06. The water to oil cooler that came with the eforce kit eliminated my oem Z06 factory engine oil to air cooler and now oil temps increased about 20 degrees (or exactly same as coolant temps)
The oil being too cool is just a myth hopefully we don't get into.
I would be VERY careful about who tunes the car! I let people tell me the handheld tuner was crap bla bla bla and I went to two of the supposed best tuners around and my car has never run great since especially cold starts, idle and off idle. All they did was make several WOT blasts and didnt even take the car for a drive around town which is how most of us use the car most of the time.
Sure, I could have brought it back but how many times? For the 30 horsepower it wasn't worth the headache and aggravation. If you go with smaller pulley then tuning may be needed but Edelbrock tech may be able to help first.
I have over 50k miles on the kit and it (the kit itself) hasn't missed a beat. I also spray meth through it.
Congrats and good luck!
I don't get into heavy traffic much so I think I should be okay with the DeWitts and factory fan. If I find that it wants to overheat, I will get the dual fan setup from DeWitts.
As for removing the factory oil cooler and installing the one with the kit, I figured that the oil would run a little hotter. My oil temps have never gone above 155 with the factory front mounted oil cooler so being at 185-195 won't make any difference. Actually, it may provide a slight power benefit. NASCAR pre-heats motor oil for all the cars before their races to 180. They have found that this give maximum power.
As far as the tune, I decided I am going to stick with the stock Edelbrock tune provided. I could spend another $500 for a custom tune but figured it wouldn't really be worth it.
I did start the install this weekend and am almost finished. It took a bit longer as I decided to remove my headers and re-install the factory exhaust as the Edelbrock tune is for a stock car. Added a few hours to the install.
So far the install has been not too bad, just time consuming. Pinning the crank was pretty easy; hardest part is getting clearance. I did not remove the steering rack, nor disconnect any power steering hoses or the cooler. Lowering the subframe, unbolting the engine mounts, and unbolting the steering rack and moving it aside gave me just enough clearance. I actually used the A&A Supercharger instructions for that part.
The Edelbrock instructions while okay could be better. More detail and better pictures would help a lot. And there are a couple of omissions in the instructions that were annoying. Part of it is just the fact that it is my first time doing the install and you just don't know what you will encounter until you do it.
Hopefully, I will get the installation finished up this afternoon.
Ground to Center of Front Wheel Well Opening
Before Install: . .26.8"
After Install: . . .26.6"
And I think that my stock clutch may be slipping at full power. The clutch felt a bit soft before and now with the supercharger, light and part throttle up to about 75%, you can feel the increased pull of the car. But when I drop the hammer, the RPM's do rise but the car isn't accelerating like it should and then when I let off a little bit, it feels like the clutch catches. I really need to drive it more to confirm but I am pretty sure. I bought the car with 19K miles on it and I don't know if the clutch was abused or not but I suspect it was.
I know a lot of people don't have any issue with the stock clutch but I want to have no doubt that I can use the full power when I want to. So I ordered a Monster LT1-S twin disk from Tick Performance.
And this will prepare the car for further power increases in the future if I want to go to a smaller pulley, etc.
Confirmed the car is pulling great and working great now. The kit definitely adds power throughout the RPM range. It's not a mind blowing difference from before; just feels like the car is much more solid and confidence inspiring.
And I am definitely thinking that I can upgrade to the 3.5" pulley and add a Boost-A-Pump. So going to do that. I think I may still go with the upgraded clutch as it is true, you always want more power.
