C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Crank pin kit
Old Apr 14, 2019 | 01:52 AM
James Heracious's Avatar
James Heracious
Default Crank pin kit
I'm replacing my stock harmonic balancer with a Power Bond Race balancer part # PB1117SS . I want to pin the crank since I have balancer off... Who makes the best crank pin kit for the LS2?? I know some crank pin kits are specific to the balancer. Any help is appreciated. Thanks.
Old Apr 14, 2019 | 02:42 AM
Blk 08 C6's Avatar
Blk 08 C6
Contact A&A.Josh will hook you up.
Old Apr 14, 2019 | 09:21 AM
CI GS's Avatar
CI GS
ICT Billet has the standard 2 pin crank pinning kit, like the one that comes with the Magnuson blower kits. This type will work with any balancer.
Innovators West has the best crank pinning kit I’ve ever seen, which uses the keyway in their balancers. But I think it’s specific to their balancers. Remember that if you’re using the standard round pin kit with an aftermarket balancer with a keyway, you need to fill the keyway with some RTV silicone before you install it, otherwise it may leak oil around the bolt.
Heres the link to the ICT Billet kit:
https://www.ictbillet.com/ls-crank-p...ture-tool.html
Old Apr 15, 2019 | 09:28 AM
TXSTICK's Avatar
TXSTICK
I have a brand new kit for sale. Cheap. It will work fine on the ls2
https://www.corvetteforum.com/forums...k-pin-kit.html
chuck
To Crank pin kit
