C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Meth test question
Old Apr 30, 2019 | 10:14 PM
HouseS2k's Avatar
HouseS2k
Default Meth test question
How much fluid flows during test? I just installed my kit (alky kit with pro meth remote tank) when I hit the test button, the pump pumps fluid but it’s not a whole lot of pressure. Let me know what your guys experience is.
Old May 1, 2019 | 08:42 AM
Patriot Six's Avatar
Patriot Six
If you detach the line from the nozzle, it flows out like water out of a garden hose without a nozzle.
Old May 1, 2019 | 08:56 AM
HouseS2k's Avatar
HouseS2k
Ok, I took the line right off the pump since it’s mounted under the drive rear cubby. And it just kinda flowed out like you described. It pumps Harder when in actual use tho right?
Old May 1, 2019 | 08:58 AM
Patriot Six
Yes, more voltage is applied while in use and operating off of the MAP input.
Old May 1, 2019 | 10:10 AM
helga203's Avatar
helga203
I think it only pumps 50lbs with the red light on. Just to test or engine will flood out. If it goes full oust around 150lb can damage engine.
Old May 1, 2019 | 02:31 PM
russ472's Avatar
russ472
It wont damage the engine. worst case is it could foul the plugs. There is a story in one of Schpenxel's threads where his boost a pump went out and caused him to break down. He drove the car home running only Meth, pressing the test button.
Old May 1, 2019 | 04:22 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
red light means 50psi or less. Could be 0psi, could be 48psi
green light means 50psi or more. could be 52psi, could be 200psi. Either way all you're getting is a red or green light
The system has no feedback system to adjust the pump to target a specific pressure or anything fancy like that,
edit: Yup, that was me. I made it too. I don't think I could get over like 30mph haha, but I made it.. wasn't enough fuel to make enough power to go faster than that. But it worked to get me a few miles or os
Old May 1, 2019 | 04:56 PM
HouseS2k's Avatar
HouseS2k
Same goes for duel nozzle setups?
Old May 1, 2019 | 05:17 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yes, same
Old May 1, 2019 | 10:10 PM
HouseS2k's Avatar
HouseS2k
Yes, same
Thanks for you help! God bless America!
Old May 3, 2019 | 11:19 AM
renegade123's Avatar
renegade123
Is it supposed to be under 50 psi ? In other words, are we looking for a red or green light for the best result ?
Old May 3, 2019 | 11:36 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There isn’t a super simple answer to that question.
The point is more that it needs to be consistent and you should be getting a green light on most setups after a certain amount of boost. When? I can’t say. It’s different for every setup and depends how the system is configured.
Old May 10, 2019 | 11:56 AM
Jason Zajac's Avatar
Jason Zajac
Pressure is in direct correlation to orifice size and restriction. Find someone or a shop who has experience with methanol kits if you are unsure. Bad toons and parts that aren't functioning correctly can cost an engine.
Old May 10, 2019 | 03:35 PM
HouseS2k's Avatar
HouseS2k
I have a date with New Era for a check over and tune.
Old May 10, 2019 | 03:54 PM
Jason Zajac
Interesting heard from shop owners in Rochester & Syracuse that they went out of business. Either way good luck
To Meth test question
