05 or 2005 Fan Upgrade
Buy an 2005 fan they said, it has a full shroud and cools better they said, it's a direct swap for 06-13 cars they said..
It might be a direct swap for a car that doesn't have a centri on it but after notching it in several places like the original to clear blower/intake tube/etc, it's still a no go. Will NOT fit with A&A bracket, F1A blower and Dewitts radiator. Looks like it's over an inch thicker than the '06 fan. Not sure how the 2005 owners are running a blower unless it's a small headunit maybe?
Guess I'm off to find a low profile dual setup that will work. Just wanted to put this out there for anybody searching for a cheap upgrade.
What is the performance on this fan? I was looking at Prospeed but they are 5 weeks out right now and I want to drive my car!
I have a 2005 with an A&A V3Si, I had no issues installing the blower, I also didn't know the 05 has a different fan shroud lol. I've never had cooling issues though if that helps!
I've seen several guys with the 05 say they've never had cooling issue and I'm guessing this is why ha. And like I said, I'm sure the thicker Dewitt radiator and large headunit isn't helping. I had to trim/shave the stock/slimmer 06 fan assembly to fit.
I should have took pics of the fans side by side but I didn't.
