C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Valves and heads?
Old Oct 25, 2019 | 11:20 AM
ZX10turbo's Avatar
ZX10turbo
Default Valves and heads?
I've been searching around for a set of heads to top off the LSR block being used to my FI build. I've come across a set of second hand MAST LS7 heads and I have a concern. The seller says the heads are using Ti valves for both intake and exhaust, I'm aware that Ti is preferred for the intake but have found very little regarding Ti exhaust valves...... so Ti exhaust valves..... good or no good? Less of a concern I think but the heads have been slightly milled to decrease the chamber size but I am assuming since I have not ordered pistons yet adjustments can be made to the proposed dish size to offset that?
Old Oct 25, 2019 | 08:13 PM
Unreal's Avatar
Unreal
Decent for NA build, but since you are doing a LSR I assume big power and you wouldn't want to run Ti exhaust in a big power FI build.
Old Oct 27, 2019 | 12:36 PM
ZX10turbo's Avatar
ZX10turbo
I think I'm going to go ahead with a set of Mast 285's, their website however offers very little information about whats in the heads.... they sell assembled heads which I assume are the cheapest valves but there is no information on that. The bare heads have options for valves and springs but again very little other info, I've emailed them some questions. If I ordered the bare heads with valves and springs do they then come assembled? Am I to assume that the valves, guides and springs are of good quality? I'm pretty new to this LS platform and heads in general.
Old Oct 27, 2019 | 09:04 PM
EnginerdVT's Avatar
EnginerdVT
I had a set of the "off-the-shelf" 305 heads a while back. They come with 70cc chambers (slight bump from the 72cc factory heads) and solid stainless exhaust and hollow stainless intake valves. Not the best for high RPM but solid. The higher end of things tends to be titanium intakes (coated accordingly) and inconel or similar exhaust valves to with stand the higher temperatures. If you call MAST, they can do the higher end valves for you with their "off-the-shelf" castings I'm sure.
Old Oct 28, 2019 | 02:56 PM
ZX10turbo's Avatar
ZX10turbo
Spoke with Mast today, got some info and now to research. Titanium valves are made by Victory and are CRN coated with a hardend tip, the Inconel valves are a premium Inconel valve similar to offerings from REV and Ferrea. Bronze guides from CHE is what they offer on tue higher end of things.
Then there is where to go rockers and such, I really don't want a bunch of valvetrain noise and will not be running a huge cam.
To Valves and heads?
By Michael S. Palmer | 2026-06-03 11:00:24
