Ls7 and boost question
at risk even with no detonation and a spot-on tune? I am considering the purchase of a SBE C6Z making 800rwhp at a bit less than 6 lbs of boost. Are the cylinder pressures required to produce that
amount of power in excess to what a stock short-block can live with?
Thanks for any insights.
Wayne
I wouldn't expect a long life out of a 800rwhp SBE blown ls7, but some people do. All depends on the octane you feed it and duty cycle it deals with. It only makes that power at WOT high RPM, so if the car is just cruised around, not raced, and doesn't see 5k+ besides a dyno once a year, it would live a long happy life. If it is something you plan to take racing every weekend, I would start budgeting a new short block now.
traps of ~140mph on what looks like decent driving in decent air. The time-slip splits mirror my passes from a 708whp C5Z so I wonder if the dyno was a bit "happy" and the power level is more in the 730-750 range.
I know driver is a big factor, but my driving pretty much sucked on the passes I compared.
Thanks gain for your input. It looks like you have real world experience with a boosted LS7 as does Russ.
Much appreciated,
Wayne
a booster LS7 is a damn animal, and a whole lot of fun, but it’s a gamble for sure...especially if you run it hard. I’d at a minimum want a forged piston set up and a refreshed bottom end(that’s what I did and I’ve got a complete rebuild thread on here) now that’s not guaranteeing me anything. I’ve got a great tuner, I run ethanol and meth and have done a lot to help it survive what I put it through....but race cars break man, **** happens.
If you follow Unreal’s build he’s spared no expense and over built, but **** still happens or you could look at Detoxx, dude has ran 700whp-1000whp on a SBE LS3 for like 40k+ miles and his **** is still running hard....it’s just the nature of the game we play unfortunately. I think going into with the mind set to keep a car like that running at peak performance is gonna take cash...a good bit and you’ll be replacing parts way more frequently then others, some things that may last the life of the car are now consumables that’s will just need replacing.
Now with that said, I’ve never not had the biggest child like smile when boost comes on just messing around, and when I’m really driving this thing I’m locked in 100% and get a similar feeling to when I am conducting high risk military training or ops down range. The danger factor is real, and respect is always given...an 800+whp C6z is real rowdy and can get away from you in a hurry! If you’ve lost traction at triple digits I’m sure you know what I’m talking about, if you haven’t....it’s an experience that’s for damn sure.
Wayne
Thanks for the reply,
Wayne
Even with a great tune, great fuel, its almost inevitable to occur due to thin cylinder walls.
Like unreal mentioned if you plan on just cruising the car and having a little fun here and there it'll probably survive and be fine.
