Back from a dyno pull on a 150 shot
So on motor alone it made 509whp previously with the 3.42s and 493whp with the 4.10s? That’s to be expected, since the higher (numerical) gear always loses a bit of power on a dyno. That alone should tell folks that dyno numbers can’t and shouldn’t be used as a “dick measuring” exercise...
What is very instructive is that fat torque curve, with the consequent ton of mid range hp which “peaks” at ~5000rpm, then dips a bit around 5500, but basically flat lines all the way past 6500, whilst picking over 200 ft. lbs. of peak torque. That’s how nitrous works.
All you need is some good drag tires in the back and some good D/A shocks to control the rear suspension, and you’re going to see some impressive numbers.
You certainly have one of the best tuners already. Bluecat is like a legend to me.
BTW: What kind of kit do you have, and how is it set up? How are you controlling it and what are you using for fueling? Enquiring minds want to know...
Ballenger AFR 500v2 wideband with ntk o2 sensor which controls my maximizer 5 controller.also have the touchscreen to change the ramp on the fly.
lnc 2000 to pull timing
nitrous outlet standalone with c16
nitrous express heater control by maximized 5 with bottle pressure sensor
pronitrous relay board
car mods
4.10 gear with MZN TR6060 mantic 9000
quicktime scatter shield/ecs trans brace
Cnc ls 3 heads milled 30 thousands 65 cc radius rod mod intake
235/243 @50 621/623 113+3
arh 1 7/8 headers /melling oil pump hp/hv cr5 timing chain
ls 7 lifters btr 660 Valves springs
all work preformed by me except for tuning
i think we all need thank Mr Chevrolet for building a great engine it sure put a simile on my face
a picture of my new hammer
