Anyone here using the "Torque Pro" app? > question
I bought one of those $12 ELM327 OBD2 Bluetooth Adapters and use the $5 Torque Pro app that works pretty good at showing the car's various sensor readings.
I normally just use it to check spark timing and boost pressure at WOT.
Question: Has anyone using the Torque Pro been able to see there fuel pressure? ... I can select either the 'Fuel Rail Pressure', or 'Fuel Pressure' PID, but get no reading from either one of them.
Thanks,
I have no experience with Torque Pro, but I’m certain you’re not going to get a fuel pressure reading, since none of the C6s (except the ZR1, I think) came with a fuel pressure sensor. If you want to read fuel pressure you’re going to have to add a sensor. And I don’t know if it's even possible to add it to a pin on the ECU so that you can read it through the ODB port. I’m sure that a few folks on here like Carson aka ‘schpenxel”, will know the answer to that though.
