All, I am installing an A&A kit in my M6 2012 GS. I have the Kenny Bell BAP and the Alky Controls meth kit. have seen people having issues with the wiring of the BAP and Alky kit. Some mentioned about racetronix wiring harnesses. I did inquire on their site but never received any reply what so ever.
Can anyone recommend what harnesses would be needed to avoid chopping up or rigging my wiring? Id rather purchase wiring harnesses that make the install plug and play than to get into my factory wiring.
Do you need a special set of crimpers for the boost interface connectors?? I have regular crimpers and was going to solder as well but was told there is a specific crimper tool that I would have to buy!
I have the racetronix harness for the BAP... but didn’t buy the connectors!! 🙄🙄🙄
Thank you
Thank you
There is a crimper for weather pack connections like this. I am sure you could find a set on Amazon.
I just used a regular crimper and some small needle nose pliers to bend the tabs over the wire and on top of each other and then crimped. Doing that and soldering, the connection will be very secure.
Thank you
Racetronix... great info... very helpful links!!!
thank you very much for chiming in..
I have heard great things... I will not run a BAP without your harness!!!
Can you please post a list of your approved dealers?
Thank you
Can you please post a list of your approved dealers for your products?? Only problem with purchasing directly from you.. is shipping costs.
Thank you
you’re going to pay shipping regardless of who you purchase from.
